Will running d16y8 (vtec) w/ p2e (nonvtec) ecu have performance issues!!!
Old 02-07-2006, 10:44 PM
cloven's Avatar
Default Will running d16y8 (vtec) w/ p2e (nonvtec) ecu have performance issues!!!
I will be getting a 96 civic dx w/ a swapped 98 ex motor (d16y8). Only thing is the new motor is still running the dx (p2e) model ecu and also still has the dx distributor and intake manifold. Vtec solinoid is also not hooked up. Car runs fine w/ no hiccups.
Question is:
- What performance will I suffer using just the dx (p2e) ecu, distributor, and intake manifold?
- Is it even worth swapping out any of these if going turbo soon?
- If I stick w/ the dx ecu, can I rig up vtec to activate w/ an apexi vtec controller?
Comments and experiences are much appreciated.
Old 02-08-2006, 11:47 AM
NJcoupe's Avatar
the p2e ecu is made to run on 190cc injectors as apposed to the EX (p2?) is made to run on 240cc's. The P2e is also made to run on a 3 wire IACV and the p2? is made to run on a two wire.
cbabyby
05-01-2012 01:11 PM
Nclette
16
04-14-2012 01:48 PM
vahonda97
12
10-13-2006 06:53 PM
cloven
03-15-2006 09:00 PM
99hatch
07-10-2004 06:22 AM
Quick Reply: Will running d16y8 (vtec) w/ p2e (nonvtec) ecu have performance issues!!!
