what's so special about the p28 ecu?
Old 06-15-2002, 06:05 PM
Charlie Moua's Avatar
Default what's so special about the p28 ecu?
I have read a lot of people say that they have a chipped p28 ecu(92-95 civic ex)
for their motors...especially for the B20vtec. Whats so special about it and what chipped program are most using.....
Old 06-15-2002, 06:34 PM
Greg L's Avatar
Default Re: what's so special about the p28 ecu? (Charlie)
There easy to find, cheaper than b series ecu, have VTEC, when chipped for hybrids, can run a b series motor without knock sensor or IABs for b18c1 which makes it easier cus u dont have to wire that junks up.
somebody correct me if im wrong on anything please.
-Greg
Old 06-15-2002, 06:39 PM
Default Re: what's so special about the p28 ecu? (WannaBFast)
whats is the IABs
Old 06-16-2002, 12:32 PM
Greg L's Avatar
it controls the secondary intake runners on the b18c1 intake mainfold
Old 06-16-2002, 03:17 PM
eg6ajk's Avatar
yes, WannaBFast is right on the money, its avaliblity and price that makes the P28 an excellent ECU, as you know, once chipped it will work the same as a P30 or P61 that has been chipped....
but a fraction of a cost, price of a P28 + chipping is alot lower then P30/P61
also P30/P61 are rather rare ecus as they were only found in for 2 years in OBDI cars, which were sold in very low numbers
Old 06-16-2002, 11:03 PM
dogpile5's Avatar
Default Re: what's so special about the p28 ecu? (eg6ajk)
pro's: bang 4 the buck, nuff said... a chipped p28 will run about the same as a stock p30/p72/p73, except you will get slightly better gains and can be reprogrammed to match aftermarket parts better than a stock ecu will do.
con's: lack of IAB for GSR manifolds, no knock sensor (bad for turbo hybrids)
obd1 only
Old 06-17-2002, 03:44 PM
Greg L's Avatar
Default Re: what's so special about the p28 ecu? (dogpile5)
con's: obd1 only
i dont see a problem with that, OBD2 sux y0!
Old 06-17-2002, 04:47 PM
dose's Avatar
i got a 92 civic si. is that a p28 ecu.also i got a gsr motor coming shuld i keep it to get it reprogrammed and wher
Old 06-19-2002, 10:48 PM
CivicHB_92's Avatar
Default Re: what's so special about the p28 ecu? (dose)
how much do p28 ecu cost?
Old 06-20-2002, 12:46 AM
SjCiViCHB's Avatar
Default Re: what's so special about the p28 ecu? (CivicHB_92)
i would say 100-150.
Old 06-20-2002, 01:25 PM
Apex i ITR's Avatar
Location: Toronto, Canada currently residing in ATL, GA, USA
Default Re: what's so special about the p28 ecu? (SjCiViCHB)
yes if you have 92-95 SI hatch it has a P28 ECU. And yes re-chip and sell the ECU coming with your motor.
Old 01-28-2014, 03:04 PM
HondaNewbie94's Avatar
I'm doing a tranny conversion from auto to manual on my 96 dx I was told to get a p2p Could I use a p28 instead?
Old 01-28-2014, 04:52 PM
Technical Hero
HondaPartsHero's Avatar
If you don't have to pass inspection with the scanner.
Old 11-17-2016, 04:44 PM
Jonathan eg6's Avatar
not only the si I have a 94 honda vx dual vtec and I'm running a p28
Old 11-18-2016, 11:17 PM
yippee-ki-yay
eHMxhACk's Avatar
First, you're replying to a 14 year old thread.
Second, only the 92-95 Civic Si and 93-95 Civic EX came with a P28 stock.
Your VX has a P28 because it has a JDM engine. A stock VX has a P07 ECU.
eH.
Old 11-21-2016, 11:23 PM
Kisal Narangoda's Avatar
Default P28 ecu
I got complete d16z6 swap it comes with p28 ecu with chio how i know what kind of a chip is that ???
Old 09-28-2017, 07:06 PM
thathondakidd's Avatar
Icon5 Re: what's so special about the p28 ecu?
was told the p28 ecu was good route for a K24A4 power build with head swap and different pistons. but seeing mostly B series info. was also told to look at a Kpro 02-04 rsx type S PRB ECU but that says it's not legal. not well versed in ECUs so help is appreciated
Old 09-28-2017, 07:30 PM
JRCivic1's Avatar
You WILL need K-Pro. The base ECU foundation could be one of many options, but a P28 isn't one of them. The PRB is the top choice... although if you aren't running a 6-speed transmission, you can use the PND or PNF ecu.
boostedeghatch
07-24-2006 11:34 AM
redwinqs
09-30-2004 03:40 PM
hotintegranights
02-08-2004 11:47 AM
brbHPR
03-13-2003 09:19 PM
Quick Reply: what's so special about the p28 ecu?
