rough idle in a b16a2 swap
Old 04-18-2003, 10:18 AM
Raff's Avatar
Default rough idle in a b16a2 swap
When i'm idleing setting at a stoplight in my b16a2 swaped into a 94 ex coupe the rpms seem to jump between 100 - 800 rpms ... also after i start the car and push it above 5k for the first time the check engine light comes on... however when i am going down the road it runs just fine except for the occasional sputter when i am not giveing it gas and the rpms are droping from a geardown/slowdown ... any suggestions guys? ... thanks for ya help.
94 Civic ex with b16a2 swap Cai/catbackexhaust
93 Prelude si Cai/head/exhaust .... soon to be sold for 3000$
Old 04-18-2003, 10:47 AM
Katman's Avatar
Default Re: rough idle in a b16a2 swap (Raff)
whats the code on the check engine light?
maybe you have some sensors plugged into the wrong plug, such as the TPS & MAP sensor (they use the same plug)......or the EGR valve and IAT plugs.
Find out what the code is and that will more than likely tell you your problem.
Nolan Simmons
Engine Management and Tuning
02-24-2019 06:33 PM
lustworld
12
10-28-2015 08:21 PM
5thgen4dr
10-30-2006 03:36 PM
AllMotor12s
03-11-2004 08:42 PM
b18civic
04-22-2002 07:20 PM
Quick Reply: rough idle in a b16a2 swap
