f20b dohc vtec into ek9 hatch need help
hi i am about to put f20b dohc vtec euro-r type R into my ek96 hatchback i not sure what year is my engine but i am positive that its a f20b euro-r type r please list what kind of axles, metal bar to hold engine, cable (cable shifter), radiator and a/c and motor mounts? will h22 fit f20b? or b20 mounts and axles fit f20b? i know they are different series and dont know what car to get those parts into holding my f20b engine. please help thanks
Re: f20b dohc vtec into ek9 hatch need help
It came from 98 - 2002 honda accord torneo Sir-T , I swapped it in my 96 honda accord and it sits on the stock mounts it means that you need 96 accord engine mounts and h swap bracket for passenger side , you can use your own wiring just consider on alternator and dizzy plugs and it will be convert it according to your wiring
Might need to extend some sensor wires or p.s hose and main fuel hose from fuel filter.
For the Ecu you can buy obd converter and get one chipped p28 ecu because it's better , but you need to use intake manifold from 95 h22a obd1 if using obd1 because p28 connects to 2 wore iacv if using ecu from sir-t then no need to replace intake manifold.
Hope it helps
Hope it helps
Im using a crank pulley from 98 accord's engine f23a and a.c from 99 odyssey with bracket and you can also use a.c from 94 - 2002 accord with bracket, I've never done swap in civic but my axles are from 95 accord for p.s you should get it from h22a with bracket
if you're using transmission which comes with f20b then use shifter cables from 98 accord
The accord chassis is completely different from an ek so accord mounts and parts are not gonna work. As for the metal bar to hold engine... common bud. While hilarious, nobody takes that kind of stuff seriously.
Ill respect anyone who successfully pulls of an F swap. Because its uncommon and takes research and skill. Time to get started!
believe the " bar" ur referring to is innovatives mounts front cross mount....part #20040 think there about $150 usd. As far as everything else goes mounts, axles, shifter cables should all be the same as the H- series swap.
Well, hopefully the OP figured it out or pushed the car off a bridge in the year since he asked his question, I hate to imagine him standing in his garage still scratching his head to this day. But thanks for your input
h22 mount kit .
hasport / innovative to name a few.
you will need a prelude h22 5 speed transmission. try and get one that comes with the f20b ( 5 speed lsd ) . or an H22 one.
you will need the shifter cables and shifter box also at the same time.
and a good write up :
https://honda-tech.com/forums/hybrid...-view-2665161/
(for future searches as this was bumped up ) .
changblood
08-02-2015 02:17 PM
Mugen_1995
10
09-04-2013 08:55 AM
