Swap Help B20a5 into Accord
I recently traded my 1990 civic hatch for a 1990 accord the car was his project I havent seen it lately and I get it saturday. He says the B20 is in there and has the axels and ecu the pedals are also in place i dont know about shift linkage because the car was also auto. He asid the wiring needs to be done and new motor mounts but I dont know what mounts I need or were to look can anyone help me out please.
Re: Swap Help B20a5 into Accord (sluger17)
no one makes mounts for a b20 in a 4th gen accord. thats a custom fab job.
... that boggles my mind why someone would swap a b20 in an accord.
no sir. motors that would fit with no prob in your car: f22a and b/f20b/h22a/h23a and b
...b series in an accord? im still lost here.
Re: Swap Help B20a5 into Accord (accrd2nr)
I dont know I get the car saturday so I wont be able to tell everything until then and ill let u know but they said the motor fits in fine just needs to be wired up and motor mounts but i now the stock mouns wont last but 2 months if im lucky.
oh **** you're talkin about the motor mount inserts, i thought you were talkin about the actual mounts. well i mean if you can find out where he got the mounts to put that motor in, there you go. you can only get the inserts for that specific mounting kit though, you cant use just any inserts. those mounts gotta be custom though i dont know anyone that makes motor mounts for that in an accord.
ok, i stand corrected. the b20b is what i was thinking of out of a CRV. the b20a is in fact an older generation prelude motor that should have fit in your accord fine. im sorry for all the confusion, just go and buy polyurethane mounts for your accord motor and they should go right in there. http://www.TASauto.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accrd2nr »</TD></TR><TR><TD CLASS="quote">ok, i stand corrected. the b20b is what i was thinking of out of a CRV. the b20a is in fact an older generation prelude motor that should have fit in your accord fine. im sorry for all the confusion, just go and buy polyurethane mounts for your accord motor and they should go right in there. http://www.TASauto.com</TD></TR></TABLE>
Sell the B20A5. Why would you want to swap that motor in your accord first of all?
Re: Swap Help B20a5 into Accord (honda4674)
I thought the B series came in the older style ludes before 92. I didn't think those engines swapped over to the 90+ Accords with OEM mounts. Are you sure this isn't an 89 Accord?
Re: Swap Help B20a5 into Accord (H2290)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H2290 »</TD></TR><TR><TD CLASS="quote">I thought the B series came in the older style ludes before 92. I didn't think those engines swapped over to the 90+ Accords with OEM mounts. Are you sure this isn't an 89 Accord?</TD></TR></TABLE>
thats what i was thinking, i knew that that B20 swapped into the older accords, but not the 90s and ups. Its a swap ive always been curious about though so good luck, you better hope buying someone elses half done work isn't a headache.
Re: Swap Help B20a5 into Accord (dmurphy2k3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dmurphy2k3 »</TD></TR><TR><TD CLASS="quote">
thats what i was thinking, i knew that that B20 swapped into the older accords, but not the 90s and ups. Its a swap ive always been curious about though so good luck, you better hope buying someone elses half done work isn't a headache. </TD></TR></TABLE>
Oh, it will be. Especially if they are putting a B20 into a 90 Accord considering I don't think anyone has ever done that. Good luck.
