B20b questions
Old 03-04-2014, 06:08 PM
hypeonline's Avatar
Default B20b questions
Im planning on getting a b20b with the p8r head for my crx and i need to get some answers,
Is the p8r head worth it its like 100 bucks more, i know it has the 33mm valves, and ill be swapping out the cams for some p72 ls cams but i need to know before i spend on it
pistons options suck for this motor i been looking of a set of cast 84mm pistons but they are hella expensive and far and few in between, any options, i was looking at a set of itr stye ycps but idk about them because this is going in my dd and i really just want reliability with a bit more than stock
what pistons come with the p8r's if they dont have the PHK's would they be worth it to get a bit more compression over the stock 9.2:1
Old 03-05-2014, 04:49 AM
kyden's Avatar
Default Re: B20b questions
what are p72 ls cams?
if you're going all motor, i would try to find some 84mm p30 replica pistons.
Old 03-05-2014, 09:22 AM
hypeonline's Avatar
I meant to say p75, p72's are gsr, the p75 are stock ls cams for the b18b's Ive read that the p75 intake cam is a bit better and the exhaust are the same, ive been looking for some p30 reps but no luck or they are hella expensive, I really wan to know whats the best option for this thing should i just do pistons/retune or will headers/retune and certain oem parts will give me a bit more punch, i have an ls in a crx so i kind of have a idea of what a b20 can do just no real solid info
i seen about the b16 im on there but it moves the peak power up 1000 rpm over stock cams
i was contemplating on getting a set of delta regrinds but idk, my goal is just to have a more peppy motor for my dd with out vtec
blwn95civic
10-12-2006 01:39 AM
civicgeek133
05-17-2006 08:41 PM
blundar
04-26-2006 09:46 PM
95lstegman
03-31-2005 08:34 AM
Dan GSR
01-14-2004 04:10 AM
Quick Reply: B20b questions
