B18A1 EG Swap
B18A1 EG Swap
Ok. I searched and could not find a definate answer for what exactly I'd need for the swap. I know I'll need ecu, axles an throttle cable however what about the motor mounts?
I plan on using an OBDI b18a1 out of a 92 integra with a b series hydro tranny to swap into my 95 civic 4dr. What motor mounts will I need or what can I use? I've seen on the net that you can use the stock civic mounts with a 94+ rear bracket but I heard the engine sits crocked to one side putting unessessary bind on the engine. Also is the b18a1 drivers side engine mount the same as the b18b1 or can I use the d16z6 stock engine mount on the b18a1? Is this true? Some help please I'm going nuts of over engine mounts
Thanks
Alex Z
Modified by Spoolind16 at 5:22 PM 10/16/2006
Thanks
Alex Z
