Honda S2000 Honda S2000
Amount of Torque for Axle Nut?
Old 07-15-2006, 11:29 AM
MeanusGeneus7's Avatar
Default Amount of Torque for Axle Nut?
Does anyone know the amount of torque that is needed for the axle nuts in the rear?
Old 07-15-2006, 12:05 PM
BKHs2000's Avatar
Default Re: Amount of Torque for Axle Nut? (MeanusGeneus7)
181 ft.lbs.
Old 07-15-2006, 12:49 PM
iam7head's Avatar
Default Re: Amount of Torque for Axle Nut? (BKHs2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BKHs2000 &raquo;</TD></TR><TR><TD CLASS="quote">181 ft.lbs.</TD></TR></TABLE>
you sure it's not 220?
Old 07-15-2006, 08:59 PM
revhi's Avatar
Old 07-17-2006, 03:21 PM
p nut's Avatar
Put a little grease on the bottom of the nut (not on the threads) and torque away. I'd even go a little higher than 220. I just usually tighten with my lug wrench (just about as hard as I can). Have had zero problems (on my ITR and S2k).
Old 07-17-2006, 03:31 PM
MasterKwan's Avatar
Pretty 1/2 assed way to do it. 220ft/lbs is what honda says (in the TSB on loose axle nuts) so, that's what I set it to.
Old 07-17-2006, 07:11 PM
iam7head's Avatar
Default Re: (P Nut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P Nut &raquo;</TD></TR><TR><TD CLASS="quote">Put a little grease on the bottom of the nut (not on the threads) and torque away. I'd even go a little higher than 220. I just usually tighten with my lug wrench (just about as hard as I can). Have had zero problems (on my ITR and S2k).</TD></TR></TABLE>
1)higher than 220? that's the way to go to kill the bearing/housing
2)lug wrench? that's 19mm for oem lug nuts and the axle nut is size 32mm
3)hand tighten? maybe with a very long cheatbar? but again, how will you know when to stop?
Old 07-18-2006, 03:39 AM
* B A N N E D *
Mr. Projekt's Avatar
Default Re: (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">
?????</TD></TR></TABLE>
Wrong again buddy. Axle is 36mm.
Old 07-18-2006, 06:54 AM
p nut's Avatar
1) Plenty of people on S2ki have taken it to 220+.
2) Ok, my mistake. It was with a ratchet and socket.
3) Why would you need a long cheater bar? What's the difference between using a torque wrench and a regular one (if they're the same length?)?? If you can't tighten the nut without a cheater bar, hit the gym a bit more.
When do I stop? Almost to the point when I can't turn anymore. Ask any of the OG ITR guys and S2k'ers. They'll tell you the same. Oh, I also don't torque down the lug nuts to the correct specs, either. My oil gets changed way before the recommended 7500 mile mark, my front license plate is chopped in half and most of the time, my hands aren't on the 10 and 2 on the steering wheel.
zda22
Honda CR-V & Element
10-05-2017 01:48 PM
DeDonDeRosa
09-07-2006 07:07 AM
EG civic
06-27-2006 09:29 PM
tsdenny
09-23-2005 06:14 PM
Euro98ITR
02-18-2004 02:46 PM
Quick Reply: Amount of Torque for Axle Nut?
