vss & power steering looping question
Old 10-07-2013, 07:15 AM
z71rider's Avatar
Default vss & power steering looping question
I want to delete my p/s on my 4th gen prelude, I know all I have to do is loop the vss and loop the other 4 lines coming out of the p/s rack. My question is do you need to have fluid in the line even when its looped? Im guessing you still need fluid. If so then how do you fill the lines in the steering rack that are looped and how do I fill the vss? Can I take the vss sensor off and pour the fluid in that hole and re install the vss sensor? Also what do i do with the sensor that plugs into the p/s line coming from the p/s pump ( i thiink its the high pressure line). do i just tape if off and delete it? (That sensor is further down the line behind the engine kinda near the steering rack and is wired into the engine harness)
Old 10-07-2013, 01:57 PM
thirsk66's Avatar
Default Re: vss & power steering looping question
Just read here and look at the pictures.....http://www.preludezone.com/4th-gen-h...chime-plz.html
Old 10-07-2013, 02:32 PM
z71rider's Avatar
i did all the research before i posted this thread so Ive seen all the pics and write ups. No where does it say anything about using fluid or not and it doesn't say what to do with that sensor. im assuming you need fluid in the system still to keep everything lubed, and the sensor you can probably just delete without throwing a code. i just wanted to make sure before i started ripping all my lines out.
Old 10-08-2013, 10:10 AM
thirsk66's Avatar
Well props to you for doing the research, not a lot of people on here do that anymore. And yes I would think that you do need fluid in there to keep everything well lubricated, why loop the lines if there would be no fluid in them that would be ridiculous. As far as the sensor goes I don't know what to do with the VSS
Fred Demara
01-04-2012 04:33 AM
94-integra-ls
07-08-2010 08:36 PM
kjlindgr
07-29-2008 07:13 PM
1SickEG
01-14-2007 05:45 PM
ImportAuto99
01-03-2006 10:16 AM
Quick Reply: vss & power steering looping question
