Timing Belt Job, what else to replace?
Old 01-05-2007, 05:35 PM
typeS's Avatar
Default Timing Belt Job, what else to replace?
Having the timing belt replaced at a shop, IMPORTS AUTOMOTIVE
2655 monument blvd E-2
concord ca 94520
What else should be replaced or changed on this list? Do I really need the valve cover set or just the valve cover gasket? Anything else that should be done? All prices are from Majestic Honda? Thank you.
1994 prelude, F22A, 115k miles, this will be the second timing belt job.
TIMING BELT.........14400-PTO-004 $34
BALANCE BELT.......13405-PT0-004 $33
CAM SEAL.............91213-PT0-003 $4
A/C BELT..............38920-P14-A02 $11
P.S. BELT..............56992-P13-003 $12
CRANK SEAL...........91212-P0A-004 $6
BALANCER SEAL......91233-PT0-003 $5
ADJUSTER..............14510-PT0-004 $52
VALVE COVER SET...12030-PT0-000 $27
WATER PUMP..........19200-P0A-003 $51
Old 01-05-2007, 05:38 PM
prelude1897's Avatar
Default Re: Timing Belt Job, what else to replace? (typeS)
need a manual tenisoner, front main oil seal
Should contact this guy to get your parts. He works for Honda up in MN and can get you great prices on parts. He saved me about $80 on T-belt parts and oil seals
Mike Blinkinsop
952-892-6253
mnhondaparts@gmail.com
Just tell him Brian sent you, and he'll know exactly who you're talking about
Old 01-05-2007, 05:40 PM
typeS's Avatar
Default Re: Timing Belt Job, what else to replace? (prelude1897)
thank you. the manual tensioner is stock on the F22 i believe. does it need to be replaced at each timing belt change?????
Old 01-05-2007, 05:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typeS &raquo;</TD></TR><TR><TD CLASS="quote">thank you. the manual tensioner is stock on the F22 i believe. does it need to be replaced at each timing belt change?????</TD></TR></TABLE>
naw, if that's what you have, you don't have to change it out...Contact this guy for all your parts
Mike Blinkinsop
952-892-6253
Old 01-05-2007, 06:35 PM
PrettyLude's Avatar
add to that list a shim to hold the balance shaft seal in place, and also replace the balance shaft seal
Old 01-05-2007, 06:36 PM
SteveoBA8's Avatar
Default Re: (PrettyLude)
Balance shaft seal retainer cheap insurance
Old 01-05-2007, 07:15 PM
typeS's Avatar
Default Re: (SteveoBA8)
cool, thank you for the advice. so, basically, don't replace my manual tensioner even if it is original? Replace the oil seal even if its been done before?
Old 01-05-2007, 08:14 PM
InvaderTrax's Avatar
You've only got 115k and this is the second time changing it? Why?
Old 01-05-2007, 09:14 PM
typeS's Avatar
Default Re: (InvaderTrax)
The reason for the second timing belt change is time. The first one was done in early 2001 at 75k miles. Its been six years. Although I don't see it, the last time I was at Honda the techs said my belts are cracked and deteriorating. I don't see and I'm ****, but why push? There is an independent shop that will do the job for $150 in labor, I can't really beat that. Its time for new coolant anyway, been a few years.
HC01
Honda Civic (2001 - 2005)
08-23-2016 10:14 AM
roadsqueegy95
15
06-07-2012 09:22 AM
safety1910
15
05-30-2012 06:39 AM
TOO MUCH TORQUE
04-18-2011 06:27 AM
Quick Reply: Timing Belt Job, what else to replace?
