Rear disc brake piston problem for H22
Old 10-15-2005, 12:21 PM
morales232002's Avatar
Default Rear disc brake piston problem for H22
Hi,
Today I try to change my rear disc brakes on my H22 vehicle, but the piston on the caliper is giving problems. I got the set of brake piston compression tool, is a tool that makes the job easier to compress the piston in the caliper , but the piston in the caliper still not going in. It has been difficult for me to install the new break pads. The two rear disc brakes are both giving problems, so I am not sure what am I doing wrong. Please, if anyone has a solution for this problem feel free to share your experience. I have no more Ideas.
Old 10-15-2005, 01:00 PM
prelittlelude's Avatar
Default Re: Rear disc brake piston problem for H22 (morales232002)
that because the rear pistons do not just rec ompress in, you have to use a large screw driver and screw the pistons back in, that is how the rear works. you don't use a compressor tool,
Old 10-15-2005, 05:09 PM
Default Re: Rear disc brake piston problem for H22 (prelittlelude)
Thanks Tom,
I was able to get the job done. Thank You one more time.
Old 10-17-2005, 02:37 PM
no problem, alot of people make this mistake if you have never done rear disk brakes on a honda, i too made the same mistake.
octaneaccord02
05-31-2008 11:41 AM
EJ8 Kenobi
06-16-2003 06:32 PM
HondaJon
20
05-30-2003 07:42 PM
flybert
02-09-2003 04:25 PM
lilcasino
07-06-2002 01:33 PM
Quick Reply: Rear disc brake piston problem for H22
