changing rear brake pad problem..
Old Jun 16, 2003 | 03:53 PM
EJ8 Kenobi's Avatar
Default changing rear brake pad problem..
Well, after having a pain time getting the caliper out, the brake cylinder wont compress back in, and I can't get the caliper back on. Anyone have any suggestions?
Old Jun 16, 2003 | 04:15 PM
DSayavan's Avatar
Default Re: changing rear brake pad problem.. (FrankGSR)
It threads on, it doesn't just compress in like the fronts.
Old Jun 16, 2003 | 04:23 PM
Rory Breaker's Avatar
Right you are...the front pistons compress with a c-clamp, the rears screw in. You can use a specific tool shaped for the piston that you can get at your local parts store, or just jam something in there and turn the SOB
-Nick, who had an awful, awful rotor/pad install sessh this weekend
Old Jun 16, 2003 | 04:31 PM
fivespeedintegra's Avatar
Default Re: changing rear brake pad problem.. (newgsrdriver)
the part you need to screw the piston back in looks like a cube. fits on a 3/8" socket and is multi-sided to fit various makes of cars.
took a few minutes to screw the pistons back down w/ the tool when i did my rear brakes.
Old Jun 16, 2003 | 04:40 PM
djay86's Avatar
Default Re: changing rear brake pad problem.. (fivespeedintegra)
i used a lot of pressure and a spackling knife
Default Re: changing rear brake pad problem.. (djay86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djay86 &raquo;</TD></TR><TR><TD CLASS="quote">i used a lot of pressure and a spackling knife</TD></TR></TABLE>
what a PITA.....the tool for a socket wrench is like $5
Old Jun 16, 2003 | 04:42 PM
djay86's Avatar
took about 2 minutes for each side and best part of it, i didnt have to go buy some 5$ tool! more gas money!
Old Jun 16, 2003 | 04:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djay86 &raquo;</TD></TR><TR><TD CLASS="quote">took about 2 minutes for each side and best part of it, i didnt have to go buy some 5$ tool! more gas money! </TD></TR></TABLE>
well then......i guess i can't argue w/ that.
Old Jun 16, 2003 | 05:47 PM
gsrclan's Avatar
I used a big flat file to turn that thing, very easy. Be careful not to twist the rubber boot.
Old Jun 16, 2003 | 06:32 PM
Lord Helmet's Avatar
Default Re: changing rear brake pad problem.. (gsrclan)
I just use a big flat chisel, it does the same thing that the cube tool does. btw I do have that special tool(cube) to push the piston back in but sometimes I do get lazy and that's why I said use a big flat chisel. just my .02
xxpaulcpxx
Honda Civic (2006 - 2015)
Jul 25, 2010 11:12 PM
octaneaccord02
May 31, 2008 11:41 AM
HondaJon
20
May 30, 2003 07:42 PM
ken
Jul 3, 2002 08:00 PM
wickedxbo1
Dec 30, 2001 07:51 PM
