no clutch pedal pressure/pedal sink to floor all of the sudden
Old 05-19-2006, 11:41 PM
vietdragontekx's Avatar
Default no clutch pedal pressure/pedal sink to floor all of the sudden
my friend have a 98 honda prelude SH. the other day, she was driving and suddenly the pedal sink to the floor and she suddenly lost pressure. change slave cylinder and rebleed it, but still have problem. pedal just sink to the floor and won't come back up. could this be that the clutchmaster cylinder went out or clutch went out on her? can a clutch went out cause this problem? anyone have a suggestion, please help. thank you
Old 05-19-2006, 11:54 PM
moderator emeritus
98vtec's Avatar
Default Re: no clutch pedal pressure/pedal sink to floor all of the sudden (apeng09)
or slave. I'd suggest replacing both.
Old 05-20-2006, 12:07 AM
moderator emeritus
98vtec's Avatar
me for not reading all of it.
i have had too many of these
time to go to sleep
Old 05-20-2006, 03:02 AM
Silver Surfer's Avatar
happened to me but i was parked and getting ready to start the car
replaced master and slave cylinder
Old 05-20-2006, 04:11 AM
SnlpeR's Avatar
my case was different
turned out to be a bad hose (got loost after 13 years)
replaced the hose, fill the res. with fluid and tried to bleed it by holding the pedal down and releasing bleed valve
did not work
had to do the submerge hose into bottle while bleeder valve open trick
it worked
Old 05-20-2006, 08:43 AM
prelude1897's Avatar
replace both your master and slave cyclinder and you should be fine
Old 05-20-2006, 09:22 AM
951dc5's Avatar
Default Re: no clutch pedal pressure/pedal sink to floor all of the sudden (prelude1897)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude1897 &raquo;</TD></TR><TR><TD CLASS="quote">replace both your master and slave cyclinder and you should be fine</TD></TR></TABLE>
true, unless you didnt bleed it right.
Old 05-20-2006, 10:30 AM
AndyD's Avatar
Default Re: no clutch pedal pressure/pedal sink to floor all of the sudden (vietdragontekx)
Don't just start replacing parts. Try to verify which part is defective first.
My first question is, did you notice the clutch fluid to be low before you replaced the slave cylinder? Did you inspect it after you replaced the slave and noticed it sink again?
First narrow down what could be defective, THEN start replacing parts. The clutch master cylinder isn't a fun job either. Make sure you are sure it is bad before you replace it IMO.
Old 05-20-2006, 10:42 AM
Default Re: no clutch pedal pressure/pedal sink to floor all of the sudden (Prelude951)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prelude951 &raquo;</TD></TR><TR><TD CLASS="quote">
true, unless you didnt bleed it right. </TD></TR></TABLE>
Need to reread the thread. He said his friend was driving and the clutch suddenly sunk to the floor, so, that means either the master or slave cyclinder went out. Either way, you should change both out now instead of having to bleed the system over again later..Yes, if you don't bleed it right, your clutch won't work.
Old 05-20-2006, 01:58 PM
thank guys, i told her to check if there fluid leaking near her master cylinder behind her peedle. also check if the slave cylinder is giving a full motion back and forth when she push the clutch pedal. but yeh i told her it definitely got to be the master cylinder because she replace the slave cylinder already and bleed it correctly. thank you for all the advice guys, ill keep you guy updated
Old 05-22-2006, 11:44 PM
ok guys, replace the clutch master cylinder and slave. bleed it with valcumn pump and hand everything. still no pedal pressure. any ideas?
Old 05-23-2006, 01:02 AM
SnlpeR's Avatar
bleed it the way the helms manual says to bleed it
worked for my problem
Old 05-23-2006, 02:10 AM
scrap1ngsr's Avatar
Default Re: no clutch pedal pressure/pedal sink to floor all of the sudden (SnlpeR)
In for result. I am currently have the same problem.
https://honda-tech.com/zerothread?id=1623946
Old 05-24-2006, 11:15 PM
Default Re: no clutch pedal pressure/pedal sink to floor all of the sudden (EbpEm1)
ok solve her problem, the clutch fluid hardline was leaking, so it keep losing pressure. we replace it and it work fine now. hope this help other people who have this problem.
Old 05-25-2006, 03:50 AM
94prelude1488's Avatar
clutch master cylinder same thing happened to mine a couple months back
Old 05-25-2006, 04:40 AM
mgags7's Avatar
and peice of the clutch system leaking bad enough is gonna make the pedal do this
Old 05-25-2006, 05:17 AM
SnlpeR's Avatar
where in the hardline?
i need to monitor mine if its leaking somewhere rather than the rubber hose which i just replaced
Old 05-26-2006, 12:30 PM
Default Re: (SnlpeR)
it connect to the master cylinder and go all the way to the tranny. it goes against the firewall. it dark greenish.
emgjsdk1
02-10-2011 05:30 AM
Acid_Dolphin
06-08-2008 09:54 PM
ge_itr
10-05-2006 01:24 PM
JoJO...
10
09-30-2005 08:56 AM
seiko
07-16-2005 02:42 AM
Quick Reply: no clutch pedal pressure/pedal sink to floor all of the sudden
