how to do coolant bypass?
Old 01-21-2003, 02:08 PM
slowone's Avatar
Default how to do coolant bypass?
how do you do it?
Old 01-21-2003, 06:23 PM
sslude's Avatar
Default Re: how to do coolant bypass? (slowone)
try asking at preludeonline.com they talked a lot about that. if it's really cold where you are, then dont do it. if you know where the lines are connected, then just take lines 1 2 and 3 4 then switch them so they look like 1 3 and 2 4. i know that was really confusing, preludeonline has pictures to show you how
Old 01-22-2003, 08:53 AM
slowone's Avatar
Default Re: how to do coolant bypass? (sslude)
thanks!
Old 01-22-2003, 10:49 AM
sharkcohen's Avatar
If you block off the fast idle thermo valve you will not have a cold start problem. I have done the coolant bypass along with blocking the fitv and have trouble free starting and idling even at temps as low as 30 degrees F.
Old 01-22-2003, 10:57 AM
GZERO's Avatar
Default Re: how to do coolant bypass? (sharkcohen)
You are right, the IAC would compensate the idle for warm up, so everything would be the same, just make sure to seal it air tight
EDIT: IM me if you want an article or help with this
[Modified by GZERO, 2:59 PM 1/22/2003]
Old 01-22-2003, 11:34 AM
JG Luder's Avatar
Default Re: how to do coolant bypass? (GZERO)
I've always heard tales of fluxuating idle when you do this.
That, and it won't really give you any hp...
Just a thought to keep in mind.
Old 01-22-2003, 12:42 PM
GZERO's Avatar
Default Re: how to do coolant bypass? (KMS Luder)
I'm with you.
BUT if you get a Hondata intake manifold gasket and remove all the coolant lines from the IM as well as the TB it will make a lil more power (please be realistic )
EDIT: changed Head gasket for intake manifold gasket
[Modified by GZERO, 5:40 PM 1/22/2003]
Old 01-22-2003, 12:47 PM
4bidden's Avatar
If you think about how this mod works.....it does work. If you have ever felt your IM after racing down the 1320 or takinga drive to the store, its BLAZING hot, just as hot as your motor basically. With this mod, the IM does not get hot at all. After driving you can rest your hand on it without burning yourself. Hot air = bad air. If the IM is hot, it will heat up the air passing through it somewhat.
Todd, in your case for the Gumball, it would help you quite a bit because you will be at high rpm's for long periods of time. The mod cools the IM even more when at high rpm's. If you are sitting at idle, this mod will not help much at all.
Old 01-22-2003, 12:50 PM
New User
lildrgn2.0's Avatar
Default Re: how to do coolant bypass? (4bidden)
THIZZUD
<--- so confused
Old 01-22-2003, 01:31 PM
sharkcohen's Avatar
Yes, the idle will fluctuate IF you do not block off the fast idle thermo valve. Block it off and everything is fine.
Old 01-22-2003, 01:32 PM
sharkcohen's Avatar
I'm with you.
BUT if you get a Hondata head gasket and remove all the coolant lines from the IM as well as the TB it will make a lil more power (please be realistic )
Hondata intake manifold gasket, not head gasket.
Old 01-22-2003, 01:33 PM
sharkcohen's Avatar
By itself I doubt the coolant bypass will give you any measureable gain in power. However, complimenting the Hondata intake manifold gasket with the coolant bypass will.
Old 01-22-2003, 01:38 PM
GZERO's Avatar
I'm with you.
you are right, don't know what i was thinking, let me go back and fix it
Old 01-22-2003, 09:08 PM
JG Luder's Avatar
I'll go along with this.
The IM gets hot because it's attached to the head... which gets hot.
Now... as far as the Gumball, I have things worked out,
Old 01-23-2003, 03:01 AM
KiDwItHaReDlUdE98's Avatar
I have the by pass done to my car..................it doesnt get very cold in Tx but when it does i kinda like the cold loopy idle ........but how do you block the fast idle control.........
Old 01-23-2003, 08:39 AM
GZERO's Avatar
Default Re: how to do coolant bypass? (KiDwItHaReDlUdE98)
Not sure what you just said buddy, but if you have a loopy idle then you have air coming in, did you make the new gasket? did you closed the FIV whole air tight?
Old 01-23-2003, 02:47 PM
sharkcohen's Avatar
You remove the fast idle thermo valve assembly from the throttle body and then reinstall it with a cardboard gasket in between it and the throttle body. You can use a ceral box to make the gasket.
Old 01-24-2003, 05:39 PM
slowone's Avatar
can anyone post pictures of this, please?
jamaicantourist
08-04-2009 08:36 PM
SpEeDyX
07-05-2009 10:59 AM
lude98SH
10-29-2006 03:17 PM
GAccord
01-29-2005 10:18 AM
X2BOARD
05-17-2002 12:57 PM
Quick Reply: how to do coolant bypass?
