Clicking Noise Coming from Valve Train???
Old 05-10-2010, 10:50 PM
rellikgtx's Avatar
Default Clicking Noise Coming from Valve Train???
So i have a clicking noise that seems to be coming from under the valve cover. Before it use to do it every once in awhile but after throwing it accidentally in to 2nd gear on the freeway it clicks all the time and gets faster the higher the r's get. Any thoughts??? I have already checked the valve clearence. Thanks http://images.ibsrv.net/ibsrv/res/sr...ilies/boom.gif
Old 05-10-2010, 10:53 PM
Lude Acts's Avatar
Default Re: Clicking Noise Coming from Valve Train???
bent exhaust valves. If you mis-shifted at freeway speed, you probably bent all 8 exhaust valves.
Old 05-10-2010, 11:07 PM
rellikgtx's Avatar
That's what me and a couple of my friend were thinking to. Do you know when Vtec is suppose to crack on a H22A? Thanks
Old 05-11-2010, 04:17 AM
Kyleb1115's Avatar
i thought it was somewhere around 5800 or so? maybe higher/lower? i dont know. mine cracks at 4700=]
Old 05-11-2010, 08:57 PM
xsmokey11499x's Avatar
mine is at 5 and a quarter.. Could just be a lifter tick eh?
Old 05-11-2010, 09:26 PM
milano_red_obd2's Avatar
have your block checked too. did the same thing and have bent exhaust valves, and a bent rod.
Old 05-11-2010, 10:09 PM
dbd6604's Avatar
4900 or 5200. Mine is 5200 but I've seen others claim theirs is 4900 stock.
Old 05-12-2010, 04:09 AM
Seroga415's Avatar
Post Re: Clicking Noise Coming from Valve Train???
how the hell does it crack at 4700... lol???
Old 05-12-2010, 12:39 PM
dbd6604's Avatar
He's probably tuned.
Old 05-12-2010, 05:24 PM
rellikgtx's Avatar
ok well when i checked it the valve lash clearence the first time, i did it to spec. So when i decided to check it one last time before i started the take the head and off and found out that the lock had "Walked" off and was gone??? lol i think it must have fallen down into the oil pan. So i got a new lock nut (which is impossible to find unless you go to Greg's Jap. Auto ) adjusted the clearence and now it runs great!!
Mine cracks at 5900-6000? lol
Thanks for all the advice
Old 05-13-2010, 07:16 PM
dbd6604's Avatar
Jesus crust that's high lol.
Old 05-13-2010, 10:00 PM
rellikgtx's Avatar
Is there a difference between a F22 and a H22 Vtec Solenoid?
Old 05-14-2010, 02:51 PM
Rasmusm's Avatar
mine is around 4700-4900 not 100% sure, had it tuned with eCtune
6k sounds to high? Stock I'd say 5400
Old 05-17-2010, 09:46 PM
rellikgtx's Avatar
Yeah thats what i had thought too. You thin getting a Vtec Controller would help that?
Old 05-17-2010, 10:08 PM
havikprelude's Avatar
mine hits at about 5400. I'm pretty sure thats stock. Either that or 5600 is stock.
Old 05-19-2010, 04:09 PM
dbd6604's Avatar
Stock is 4900.
Old 05-20-2010, 11:30 AM
DCFIVER's Avatar
Originally Posted by dbd6604
Stock is 4900.
no I beleive stock is 5200, and 4900 i beleive is when the IAB's open. (could be wrong though)
Old 05-20-2010, 02:11 PM
Rasmusm's Avatar
All VTEC hondas I've driven VTEC engages over 5k rpm, except mine cause I had it tuned
And im pretty sure a H22A engine its around 5200-5400
d17beast
Honda Civic (2001 - 2005)
11-12-2010 03:12 PM
Dav94Lx
10-09-2007 07:53 PM
OBRJosh
08-09-2006 05:25 PM
Quick Reply: Clicking Noise Coming from Valve Train???
