1989 Prelude starting problem.
Old 06-11-2009, 06:53 PM
New User
BrettFulton's Avatar
Default 1989 Prelude starting problem.
Proud owner of an 89 Prelude Si. The car has been flawless for 20 years, until the other day. Won't start. Battery ok, battery cables ok, changed out the starter, so that is ok now. Turn the key in the ignition, all the lights come on, but not a sound and it won't crank. Lights, sun roof, windows work, but it won't start. I can get it to start by pushing it and letting the clutch out in first gear, but it will not start by way of the ignition switch. Any ideas? It's doing the same thing as if I did not push the clutch pedal in all the way.
Old 06-11-2009, 07:20 PM
be professional
Targa250R's Avatar
Default Re: 1989 Prelude starting problem.
Check the clutch switch.
Old 06-12-2009, 06:35 AM
Hawkze_2.3's Avatar
Yep, check clutch switch, fuses, etc first.
Old 06-12-2009, 04:24 PM
New User
Thanks for the replies. You were right. It was clutch pedal switch B. The little plastic part which depresses the pin broke. Switch B is not easy to find, unlike Switch A which is easy to see. The old '89 fires up now. Thanks again. Brett....
Nikki Aulicino
01-26-2017 10:25 PM
magicmyst98
14
09-02-2013 12:06 PM
pkarandi
04-28-2006 07:47 AM
wood
08-16-2005 07:09 PM
M-EJ1
12-15-2002 06:24 PM
Quick Reply: 1989 Prelude starting problem.
