Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Help with 2007 Honda Odyssey trouble code P0175
Old 12-01-2016, 12:55 PM
bikesusa888's Avatar
Default Help with 2007 Honda Odyssey trouble code P0175
Hey guys, I need help with my 2007 Honda Odyssey trouble code P0175, fuel system too rich. I already replaced the bank 1& 2 oxygen sensors. I also clean the egr valve, I also cleaned the air flow sensor. The car is runing really well in high speed the problem is when I got in the traffic the car is vibrating terrible. The engine mount is good. I went to auto zone for my car to be scanned the code that I got is P0175 fuel system too rich bank2. Probable cause fuel system concern, ignition system concern, MAF sensor faulty, H02S/AF heated oxygen sensor /air-fuel ratio sensor fault. Also sometimes I had hard starting vehicle.
Old 12-01-2016, 03:29 PM
lazlong's Avatar
Default Re: Help with 2007 Honda Odyssey trouble code P0175
1. You may need a valve lash adjustment. Notice the valves making more noise than usual? Should be done every 60-100K miles anyways.
2. Bad injector(s)
3. Bad fuel pressure regulator
Old 12-01-2016, 06:07 PM
I forgot also to mention. I have display sign on my dash. Check fuel cap. Is this related to this problem?
dejay2014
08-24-2014 09:16 PM
SoHc94
17
04-20-2007 11:35 PM
Dc2 Joe
02-02-2006 08:14 PM
lamsv
11-23-2005 10:13 AM
monsoon
11-21-2002 08:54 PM
Quick Reply: Help with 2007 Honda Odyssey trouble code P0175
