Honda Fit Honda Fit (Jazz)
Front Hub Question
Old 07-12-2008, 07:15 PM
WillItFit's Avatar
Default Front Hub Question
So today i had some free time and wanted work on the Fit for a bit and i had some extended studs and lugs lying around. I start to install the back 1st cause i know it was going to be easy. Then after i was done, i proceeded to move to the front. i got the wheel off and rotors off fine but then when it came down to getting the hub off, i nearly pulled my arm's off. I used the slide hammer (About 10lbs). After about 20min of sliding and hammering, i managed to budge it about half a cm. lol. So my question is, i was wondering if anyone on HT had done a stud change on the Fit and if so how did you manage to get the front hub out. Thank you your input would be very much appreciated.
_Keith_
08-01-2008 12:16 PM
stealth_EK4
Honda Civic (2001 - 2005)
04-11-2008 08:23 PM
Historyg
02-14-2008 05:49 PM
fridexter
08-31-2004 03:36 PM
DruWO
04-24-2004 09:17 PM
Quick Reply: Front Hub Question
