Honda Fit Honda Fit (Jazz)
Coolant Drain on Engine Block
Old 03-27-2011, 01:50 PM
JVH
JVH's Avatar
Default Coolant Drain on Engine Block
Hi, does anyone know the exact location of the coolant drain on the engine block. The manaual says it is above the oil filter, but I can not find it. Thanks.
Old 03-27-2011, 05:23 PM
2k.civic.si's Avatar
Default Re: Coolant Drain on Engine Block
is there a reason you need to drain the block?
Old 03-27-2011, 10:44 PM
claymore's Avatar
Try removing your oil filter and then you can see the drain above it on the front side of the block above the oil pressure sending unit. Save the filter and re-use it.
Old 03-28-2011, 05:41 AM
JVH
JVH's Avatar
Thank you. I will give it a try, and let you know.
Old 04-01-2011, 12:41 PM
der Mond's Avatar
I had trouble finding mine also until I realized that the coolant drain is where they screw in the block heater. If your car has a block heater, remove that. It's not easy to get to but is possible. I do it straight in from the front but had to remove a little dipstick support piece, I think it was.
Honderachinaldo
07-16-2019 08:28 PM
paulsomlo
Honda Civic (2001 - 2005)
10-24-2014 08:48 AM
ActiveAero
10-02-2005 05:03 AM
turbotime
16
11-27-2004 06:28 PM
HoNdAeX11
07-16-2002 04:32 AM
Quick Reply: Coolant Drain on Engine Block
