vtec oil pressure switch problem
Old 05-29-2005, 04:26 PM
LudeJdm's Avatar
Default vtec oil pressure switch problem
88 hatchback d16z6
chipped p28
obd0-obd1 conversion harness
no plug to go into vtec oil pressure switch
ive been getting code 21 which is vtec spool solenoid...so i rechecked my instructions from the place i got the conversion harness and it says green wire to vtec oil pressure switch and black to vtec solenoid...so today i recheckd my wires and it seemed like my homeboy who did the conversion got the wires crossed and had black to nothing and green to solenoid...so i re did them....i had green go to ground and black to solenoid....the only reason i had green go to ground because i dont have the plug that goes into the oil pressure switch....so i reseted the ecu and checked my codes again...code21 is gone now but getting code 22....is there a way to get vtec working and get rid of code 22 without getting the plug for the switch....remember im using a conversion harness....
Old 05-29-2005, 09:53 PM
LudeJdm's Avatar
Default Re: vtec oil pressure switch problem (lbautista23)
http://www.50mod.com/fourthgenhatch/mpfi.html
this is what im looking look at the mpfi side....someone tell me which wire do i piggybank to a6
SinsEvil666
09-12-2009 08:26 AM
drudy
08-26-2005 12:20 PM
LudeJdm
11
06-19-2005 06:23 PM
LudeJdm
05-29-2005 09:52 PM
singlecamcrx
11-24-2004 02:10 AM
Quick Reply: vtec oil pressure switch problem
