oil pan gasket is squeezing
Cliff notes at the bottom.
Yesterday I go to fix my oil leak from the oil pan gasket that I just installed 150miles ago. The gasket squeezed out the sides, so I figured i could take the oil pan off and move the gasket over and tighten it back down. Well, once I had the oil pan off I find that I squeezed the gasket to much a riped the gasket. So I get a new gasket last night.
Today:
I clean the oil pan and the bottom of the block and wipe it down with carb cleaner to make sure the gasket doesn't slip out. So I have the gasket and oil pan back on the block and I'm tightening the nuts down. I get the torque wrench to make sure that I'm tightening them evenly and so I can tighten the nuts in stages. I make sure the us the correct sequence. Well I hand tighten all the nuts and use a socket to tighten them up a little more. Then I put the torque wrench on with it set a 2ft.lbs. and when I was done tightening all the bolts to 2 ft. lbs the gasket was starting to squeeze out again. So how much is the gasket supposed to squeeze out once it is torqued to 7ft. lbs or how can I stop the gasket from squeezing out?
Cliffs:I'm tightening the oil pan nuts and at 2ft. lbs. the gasket is squeezing out. How much is the gasket supposed to squeeze out or how can I stop the gasket form squeezing out?
Thanks for the help
Today:
Thanks for the help
Re: oil pan gasket is squeezing (george34)
All of the gaskets that I've installed have squeezed out and I haven't had any problems. I thought it was weird too the first time it happened but it never leaked on me so I was happy.
a little should squeeze out, i've replaced tons of b series oil pan gaskets, they always do, i say if its not leaking.... ***-it
Did you ever have leaks with your gasket that was squeezing out 1/4"? I just did an oil pan gasket on a D16Y7 civic that squeezed out about 1/8" all the way around. It's even at least, so I'm not too worried about it, but wanted to hear how yours turned out.
This thread is 10 years old. Please create your own thread in the 92-00 Civic forum.
imadigitalgod
04-08-2010 09:48 AM
