Loud noise, play in differential?
Well, i seem to have a problem ive never experienced before. It all started after having to use some nasty old tires that were way outta balance. Had no money to replace slashed tires on good wheels, and had to drive it the way it was, unbalanced and all. I though i loosened up a tie rod or ball joint, but i come to find one bad tie rod, and i repleaced it. It still makes this awful clanking noise when i hit small bumps in the road and what not. When the car is in the air, nothing is loose, but there is some play when i rotate one tire, it takes a second for the other tire to spin the other way. Does this sound normal, it seems to make that noise im looking for when the other axle catches and starts to turn. Any input would be appreciated, im slowly getting this thing back together and running good after a bunch of vandalism.
96hondaAccordV6
04-24-2007 02:15 PM
