How tight to tighten lug nuts on wheels??
Old 09-24-2009, 07:56 AM
  #26
apekd's Avatar
Default Re: How tight to tighten lug nuts on wheels??
Originally Posted by dacrxguy
wow i would never let you work on my car the spec is 80ftlb ii hope you never use a 500ftlb gun
some manufactures recommend cheking the tourque after 20 miles on aluminom wheels
Yeah, if he was near ANY of my families cars, I would shoot him lol I would NEVEr endanger ANYONE. When I was working at Ford it was Gray Torque stick (95-100 Ft lbs) and then checking it with a torque wrench. I made sure EVERY car was safe before leaving our shop. the last guy who did my job fawked up and sent one guy home with a tire just "snugged" and it ended up snapping all but 1 lug stud.
Old 09-24-2009, 07:57 AM
  #27
Keyboard Humorist
4drEF's Avatar
So you can have some 'WHY' here.
The thread pattern and material determines the torque.
It's engineering and I'm not going to type out formulas for you.
You need to know the following:
- friction factor
- diameter of the fasteners
- bolt tension
Most every car is 80lbs torque. A little more or less isn't going to hurt.
Different materials will affect friction factor.
Old 09-24-2009, 07:59 AM
  #28
apekd's Avatar
^which is why i am glad they dont make aluminum studs....they would snap really fast
Old 09-24-2009, 08:06 AM
  #29
michael-crxsi's Avatar
How do you know if you over tightened your wheels? Or warped your brake roters?
Old 09-24-2009, 08:38 AM
  #30
apekd's Avatar
if you have warped rotors your steering wheel will shake a tad bit, and youll feel the car have spot that feels like its getting more friction
Old 09-24-2009, 08:54 AM
  #31
Keyboard Humorist
4drEF's Avatar
You won't know if you over-tighted your wheels unless you use a torque wrench.
Really a necessary tool if you do work on your car. Every bolt has a torque spec.
Old 09-24-2009, 09:19 AM
  #32
apekd's Avatar
yup thats why I have one. Probably the LEAST used tool, but it saves your *** a lot
Old 09-24-2009, 11:17 AM
  #33
dacrxguy's Avatar
this and you can tell if you have a dial indicator
this an invest in a good decent torque wrench i will never torque someones wheels without it(if i am working on buddy's car ill make him do it) because if the wheels fall off then i do not want to be responsible for it.
it is ok to use a torque stick as long as you regulate the gun with the stick and then follow up with a torque wrench.
remember if the studs have different torque there is a possibility that the ones with less torque might make themselves loose that is why it is important that almost all the lugs be within a certain amount of torque
ps safety first kids you can replace a vehicle but you cannot replace a human anything
Old 09-24-2009, 12:38 PM
  #34
apekd's Avatar
WHAT?! But a guy in NY just said that if I know anyone that needs a kidney he has several needing transplant very soon lol
Old 09-24-2009, 01:57 PM
  #35
dacrxguy's Avatar
very soon what does that mean must be some black market ish
BoostedGSRBubble
10-30-2002 09:04 PM
sutrusu
06-20-2002 06:52 AM
nijia555
06-07-2002 10:38 AM
distuRbed
05-24-2002 03:38 PM
Quick Reply: How tight to tighten lug nuts on wheels??
