How to test for a bad CV joint? help....
Old 09-14-2002, 02:21 PM
TimsTeg's Avatar
Default How to test for a bad CV joint? help....
I finally got my car running perfect and when i take left turns there is a clunking sound coming from the front end. I think it is the CV because it does it with the clutch in and with it out. It is only when i take left turns. Anybody know how to test to make sure it is the CV so i dont' waste more money?
Old 09-14-2002, 02:32 PM
PhatOptimo's Avatar
Default Re: How to test for a bad CV joint? help.... (Accord092)
If it knocks during turn its most likely the axle. You might feel a little odd vibration coming from there 2. You can also get under the car and look at the boots. If they are torn they need to be replaced. Its also a good idea to change them both at the same time. HTH
Old 09-14-2002, 02:43 PM
90-CRXSi's Avatar
Default Re: How to test for a bad CV joint? help.... (Phat_Optimo)
I have the same problem on only left turns. I have a b16 swap and it seems my cv joints are binding up when turn. I've taken it to like 3 local import shops who do swaps and they don't know why it is. Anyone have any idea.
Old 09-14-2002, 03:40 PM
SteveeeO's Avatar
Default Re: How to test for a bad CV joint? help.... (90-CRXSi)
it's the axles ... did it to my car too, they wanted $400 LOL! so I said screw it and got a new car
Old 09-14-2002, 04:33 PM
performula's Avatar
Hold on. It's the CV joint or the axle?
When do you know to change the axle?
Old 09-14-2002, 04:49 PM
Hcivic88's Avatar
Default Re: How to test for a bad CV joint? help.... (performula)
i dont think you can replace just the joint, you have to replace the axle, theres a short one on the passengers side and a long one on the drivers side, they're not too hard to do, just did mine last week.
Old 09-14-2002, 05:03 PM
PhatOptimo's Avatar
Sorry, I should have been more clear. You are going to need to change the whole axle not just the boot. If the cv joint is knocking the axle must be changed. You know to change the axle when it make a noticable popping noise when you turn. Change both axles out at the same time even if only one is knocking/popping.
*EDIT* some shops will rebuild your axles for you but its gonna co$t.
[Modified by Phat_Optimo, 8:05 PM 9/14/2002]
Old 09-14-2002, 05:18 PM
shortyz's Avatar
yeah change both axles. its easy.
Old 09-14-2002, 09:13 PM
h8tred's Avatar
Location: Commonwealth my ass This is the communist state, VA, USA
Default Re: How to test for a bad CV joint? help.... (shortyz)
Sounds like something is up with the axle its self to me... He said it does it when the clutch is in. If it were the cv, It would only do it when power is applied. Did you get new axles with your swap? Your stock axles will not work, I think the driver side is too long. Here is a link to a good write up on it... http://www.hasport.com/B16axles.htm
[Modified by h8tred, 1:13 AM 9/15/2002]
Old 01-30-2021, 04:32 PM
Charlie Grant's Avatar
[QUPMOTE=performula;2689107]Hold on. It's the CV joint or the axle?
When do you know to change the axle?[/QUOTE]
IntegraR0064
09-22-2012 03:26 PM
mingbling96
03-20-2005 01:16 PM
JDM R
12
08-27-2004 04:15 PM
d_mina
11-27-2003 12:09 PM
Greyout
01-21-2002 02:00 PM
Quick Reply: How to test for a bad CV joint? help....
