How to pull and clear CEL codes from your OBD0 ECU
Old 10-21-2012, 08:24 PM
Former User's Avatar
Default How to pull and clear CEL codes from your OBD0 ECU
The diagrams below should be self explanatory.
If the ECU throws one or more of the below codes, then the next step is to reset the ECU (clear codes) to see whether any of the codes return after driving the car or cranking the engine for 30 seconds.
**Reset the ECU (clear codes) by removal of the 10A Hazard fuse from the hood fuse box for about 5 minutes.**
If the code(s) doesn't return immediately or eventually, then do nothing.
If the code(s) returns, troubleshoot the problem as described in the service manual. Or create a thread if you need help.
Former User is offline
h0nda n00b
Engine Management and Tuning
02-27-2014 09:13 AM
edro13
11-20-2009 03:05 AM
jpar195
04-07-2008 12:01 PM
drumminforev
19
10-06-2006 12:12 AM
Quick Reply: How to pull and clear CEL codes from your OBD0 ECU
