ef start/run issues update
Old 01-18-2011, 03:51 PM
Nooch's Avatar
Default ef start/run issues update
1990 base model 3dr
zc sohc swap (mpfi conversion)
car ran fine for 6+ months
new battery, starter, fuel pump and filter, new plugs
main relay was recently replaced
problem: car cranks but doesn't start every time. got it to start once after changing fuel pump, idled fine, went to drive off and car died
i've checked the main relay, ignition switch, plugs/wires, cap and rotor look good
i know i'm getting fuel to the cylinders
i think it could be the key cylinder/ignition switch or the weak yellow spark i'm getting at the plug and coil
i tested spark by pulling a plug wire, attaching a spark plug and grounding it, got a dim/weak yellow spark; did the screw driver method as well, same result. pulled a spark plug wire at the coil, same weak yellow spark (http://techauto.tripod.com/ as guide on how to do most of the testing i've done)
could the coil or something at the distributor be bad?
Old 01-18-2011, 03:57 PM
alex14's Avatar
Default Re: ef start/run issues update
Cheapest thing to do first would be the cap and rotor. seems like if the rotor was making poor contact with the cap it would give weak spark.
Old 01-18-2011, 04:30 PM
tonythetuner®'s Avatar
Any cel? If not try testing the coil. This link has. A right up how to do ithttps://honda-tech.com/forums/showthread.php?t=2624753
Old 01-18-2011, 08:17 PM
Nooch's Avatar
NO CEL
going to throw on a new cap and rotor, crossing finger, but not too hopeful
a lot of the issues i'm reading about bad distributors/coils/ICMs have NO spark, where i have a weak looking yellow spark
the distributor has 40K miles or so (as does the engine), not 150K, which is the indicated lifespan in the link you posted for a distributor
Old 01-18-2011, 10:28 PM
Nooch's Avatar
Any other ideas anyone?
Old 01-18-2011, 10:58 PM
BiG ChOr!Zo's Avatar
i was expecting a update to the previous thread you created lol...!!!
Old 01-19-2011, 07:55 AM
acmoc's Avatar
Ground cab;es
Old 01-19-2011, 09:14 AM
Nooch's Avatar
This is a more informative one now.
Originally Posted by acmoc
Ground cables
Fix'd, and grounds are all good.
Anyone else?
Old 01-19-2011, 10:22 AM
munchlax's Avatar
fuel injectors? Let me know if you get it fixed, I've got the same set up but automatic and carb looking intake mani. My pump doesn't work, but worked on and off. now it doesn't.
Old 01-19-2011, 01:20 PM
munchlax's Avatar
how recent did you replace the main relay? try changing that again.
Old 01-20-2011, 11:54 AM
Nooch's Avatar
Up.
Old 01-21-2011, 10:22 AM
munchlax's Avatar
dizzy coil pack? I fixed my crx, my problem was the main relay, even though it still clicked and everything, I changed it and it runs great again.
MrConti
12
06-29-2017 05:26 PM
platinum_rich
15
02-25-2012 08:16 PM
thereverendstu
01-25-2010 08:16 PM
DelSlowmo
61
02-12-2009 07:50 PM
Quick Reply: ef start/run issues update
