EF Hatch. How do you remove the left vent on the dash?
Old 07-24-2003, 10:56 AM
I said I don't want a title!
Todd00's Avatar
Default EF Hatch. How do you remove the left vent on the dash?
As topic says. Is there a simple way to get the left vent cover to come off (the one to the left of the steering wheel)? I need to get into there to run a vacuum, but it's not worth it if the vent is a PITA to remove.
Old 07-24-2003, 11:08 AM
4crx4me's Avatar
Default Re: EF Hatch. How do you remove the left vent on the dash? (Todd00)
Yes, BIG PITA.
They are VERY fragile. Ask me how I know.
Pry out gently with a flathead screw driver.
BE CAREFUL. there are 4 clips on the underside, sort of reaching up
and holding on to the inside part of the dash.
Old 07-24-2003, 11:11 AM
Vinceg99's Avatar
Default Re: EF Hatch. How do you remove the left vent on the dash? (4crx4me)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4crx4me &raquo;</TD></TR><TR><TD CLASS="quote">Yes, BIG PITA.
and holding on to the inside part of the dash.</TD></TR></TABLE>
Yes like he said big PITA!!! those clips are hard to get to there will be 2 on top and 2 on the bottom if memory serves me right. I dont get it in the manual they make them seem easy to get off!!
Old 07-24-2003, 09:13 PM
redEFnine's Avatar
beyond pita! i pulled all of mine out since i was yanking the dash from my car and i just used two pretty wide flatheads (as upposed to smaller ones that might tweak the fragile plastic) and just slowly worked it out.
Old 07-25-2003, 09:33 AM
CRXRageD's Avatar
Old CRX vents are very brittle especially if your car is 15 years old like mine. I choose not to mess with them. I'll end up destroying them if I do. They are just way too old.
Old 07-25-2003, 11:30 AM
highhopes's Avatar
Default Re: EF Hatch. How do you remove the left vent on the dash? (CRXRageD)
agreed...I broke them when a mouse made a nest in the air passages...had to get new ones from the junkyard, and I only got those out by cutting up the entire dashboard; the far right passenger's vent is the same way.
ej6hatchie
Paint and Body
05-14-2008 09:48 AM
DC4_MADMAN
10
08-15-2005 03:03 AM
toooslow
05-27-2003 02:00 PM
01-1293
03-31-2002 08:38 PM
charjacq
10
02-16-2002 07:23 AM
Quick Reply: EF Hatch. How do you remove the left vent on the dash?
