Changed cap & rotor.... distributor now makes loud ticking noise?
Old 12-08-2007, 12:16 PM
rayzian's Avatar
Default Changed cap & rotor.... distributor now makes loud ticking noise?
It's freezing outside and I just finished it up and when I started it up, the first thing I noticed was a loud ticking sound..... probably the rotor, but why? I had it on pretty tight... dizzy never had this problem before.. when I did first take it apart, the original rotor was on very loose and there was black "debris" all inside of the cap... any help is appreciated..
Old 12-08-2007, 12:41 PM
97grnrs's Avatar
Default Re: Changed cap & rotor.... distributor now makes loud ticking noise? (rayzian)
maybe its hittin that plastic shied inside that sits under rotor. pull if off
Old 12-08-2007, 12:51 PM
ludesrv's Avatar
Open it up and it should be obvious as to what's been hitting what. Just look for scuff marks on the plastic. Remove/adjust accordingly.
Old 12-08-2007, 02:50 PM
turboZChatch's Avatar
Default Re: Changed cap & rotor.... distributor now makes loud ticking noise? (97grnrs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs &raquo;</TD></TR><TR><TD CLASS="quote">maybe its hittin that plastic shied inside that sits under rotor. pull if off </TD></TR></TABLE>
could be the wrong rotor also........had a similar problem with a car I bought only when i took the cap off I saw that whoever had the car before me used tape instead of a screw to put the rotor on one of the funniest things i ever seen
JWilley
01-26-2007 12:17 PM
Extreez
01-03-2007 04:33 PM
MantisX
10-20-2005 08:40 AM
superhatchbackbros
05-19-2005 04:54 PM
G2DAteg
03-28-2005 03:58 PM
Quick Reply: Changed cap & rotor.... distributor now makes loud ticking noise?
