A/C wiring diagram?
Old 05-24-2014, 04:27 PM
PhilipK73's Avatar
Default '91 Civic: A/C as kill switch
I am trying to turn my A/C switch into a kill switch for my '91 Civic htbk. Does anyone know which wire is for the button toggle?
Old 05-25-2014, 07:37 AM
Former User's Avatar
Default Re: A/C wiring diagram?
What car? See forum Rules sticky.
I hope you don't have and don't want A/C.
Old 05-25-2014, 06:25 PM
PhilipK73's Avatar
Fixed.
And A/C does not work in the car and I don't have any desire on fixing it.
Old 05-25-2014, 06:29 PM
Old 07-22-2016, 12:33 PM
texaca's Avatar
hello RonJ what year model does that a/c circuit diagram apply to, I don't see anywhere on the image, what this schematic applies to.
Thank You, Alfredo
Old 07-22-2016, 03:52 PM
88-91 Civic
Old 07-23-2016, 12:41 PM
fcm
Old Fart
fcm's Avatar
You can get away with using just the blue/red from the A/C switch, it is a ground when any blower motor speed is on, it can be used to trigger a "starter cut relay", [turn a relay on], lust using it allows the A/C light to also work as an "on" indicator.
The switch will not "carry" enough current to use it by itself as the starter cut, unless your car is a 5 speed, [standard] then you can run the CIS, [clutch interlock switch] output or ground input through the switch, use the green lead into the switch for the input and the blue/red for the output, the A/C indicator light will still work. 94
Marks accord
07-14-2015 06:30 PM
I Am White
05-21-2010 05:34 AM
BB6-213
12-27-2005 12:47 PM
Forbesy
01-15-2005 12:42 PM
Quick Reply: A/C wiring diagram?
