blown head gasket??
Old 04-26-2005, 06:54 PM
Bobby808's Avatar
Default blown head gasket??
Today I was at drivethru sitting for a while and car started to overheat and coolant was bubbling and leaking from reserve tank. There are no other symptoms of blown head gasket no white smoke or oil in coolant or vice versa. I checked and radiator fan doesn't seem to be working either. Would this be a blown head gasket or was this cause from fan not working. When normal freeway driving car does not over heat.
Old 04-27-2005, 10:13 AM
Bobby808's Avatar
Default Re: blown head gasket?? (Bobby808)
would I know if it was the head gasket from performance. The car still accelerates very well and like I said doesn't overheat on freeway. I guess I am going to try to get fan running first which should help. I just want to make sure it is not head gasket so I don't mess anything up worse.
Old 04-27-2005, 10:31 AM
Built B16A's Avatar
Location: hittin corners so hard you can taste my rims..
you need to know why the fan isn't comming on in the 1st place. this is probly your problem.
either it be wirring, or the acutal fan thermo switch on the head.
changing your thermostat at the upper radiator hose wouldn't be a bad time to change either.
Old 04-27-2005, 10:38 AM
Steve91's Avatar
It sounds like boiling coolant and not a headgasket (at least not yet). Get that fan fixed pronto.
Old 04-27-2005, 10:49 AM
Bobby808's Avatar
Default Re: blown head gasket?? (Steve91)
thanks for the replies going to work on getting fan running.
Old 04-27-2005, 11:04 AM
Banned
LSVTEC 91 Civic's Avatar
Just put a switch on the fan for now... You don't want the car to idle for very long without teh fan.
Old 04-27-2005, 11:22 AM
Bobby808's Avatar
Default Re: (LSVTEC 91 Civic)
Fixed it. I feel dumb. After searching found there were 2 fuses I had only checked the one under the hood. Turns out the one under the dash I had not checked was blown. Now right before temp gauge hits half fan comes on. Hopefully this ends my overheating in traffic/drivethrus. Thanks for all the help guys.
DrewBrews
13
12-21-2011 08:33 AM
BlackShingo
05-06-2010 03:56 PM
efjones9
05-01-2009 06:48 PM
marvinmark21
01-14-2008 04:21 PM
Quick Reply: blown head gasket??
