1991 Honda Civic DX - incredible slew of problems
#27
Re: 1991 Honda Civic DX - incredible slew of problems
Oh I didn't see that list in your post. Thanks, although I'd still be clueless as to how to do this. Is there any diagram or anything that would help me out? I found a post on this forum from 2006 with a diagram but the link went nowhere.
#28
Interesting thread...
Here are some dumb suggestions to get you to spend more $$$
- Replace the fuse box.
- Check all other fuses and wiring for shorts.
I have had to replace the under dash fuse box before.
#29
gotta agree with vem on this one as my car went through a similar hellish scenario ....checking grounds is easy remove them and clean the cable ends and there mounting points check for broken wires then reinstall... voila ... you're grounded
#30
You can also test the grounds with a volt meter...one lead on the ground wire and the other lead on the metal it is grounded to. If it reads 0 mV, you have a good connection. If it jumps around, or reads 50, 100, or more mV, you do not have a good electrical connection. You can also test it from the ground point back to the negative side of the battery the same way.
#31
The under the hood fuse box goes bad also sometimes causing a random shut down. Usually tapping on it will get it to come back/go out. If so replace it.
#32
Does anyone know what the root problem ended up being? I'm having the same problem and would like to know if it's as simple as a bad ground before I start throwing parts at it.
tatz9977
05-28-2012 07:47 PM
octodigitus
08-08-2011 09:22 PM
