Valve Adjustment
Old 07-10-2011, 12:26 PM
journeyquest's Avatar
Default Valve Adjustment
I have the new head on my d15 and everything is torqued to spec. Do i adjust the valves before i install the timing belt? Im pretty sure this is correct. Just checking to make sure. Thanks
Old 07-10-2011, 12:30 PM
Orangegsx's Avatar
Default Re: Valve Adjustment
It'll be easier to adjust the valves after you install the belt.
Old 07-10-2011, 12:34 PM
DO IT ON ALL FOURS
OneBadTurboCRV's Avatar
Preferably, I would have the valve adjustments backed off and put the timing belt on. That way in case you have it off a few teeth or something of that sort, you won't ruin anything checking mechanical timing. After you're done and timing is correct setting valve lash is a breeze anyways.
npoutre
Honda CR-V & Element
10
06-20-2019 01:48 PM
young geezer
05-21-2009 08:37 AM
vxnine
12
10-14-2004 07:41 AM
Quick Reply: Valve Adjustment
