Wiring in ftp sensor on 96 dx swap
Ok i'm running a 96 dx hatch with 99 b16a2 with 99 ecu with ry wire obd2b to obd2a jumper harness.
So im getting code 91 for fuel tank pressure sensor.
So today I got a ftp sensor from a 98 lx automatic... are the auto/5 speed the same?
and evap canister with solenoid valve on it.
wires I need to wire into the ecu?
and this is a extra plug I have hanging loose that fits on the canister i'm not sure why it's there though on a dx harness?
and here's the pin out
If anybody could help with the ftp sensor part with the 5 wires that's what i'm trying to figure out thanks.
Re: Wiring in ftp sensor on 96 dx swap
https://honda-tech.com/forums/hybrid-engine-swaps-18/%2A-%2A-obd1-b-series-engine-into-obd2a-obd2b-civic-integra-%2A-%2A-1972711/
if you have a 96 civic won't the use of jumper harness automatically fail you? ... if they see it? (most are marked "for off road use only" at least mine is)
I have b18c1/b16 in a 99 civic ex and I have to run 99-00 ex PTP OBD2b ECU to pass inspection (bar, as you call it) here in NC, I don't know what state you are in but shouldn't you run a OBD2a PTE ECU without a jumper harness?
The way you are doing it in my state it would still fail and its alot of work for what you are doing, if I am wrong please explain as your explanation could help someone else answer your question.
Last edited by 420eg95; 05-22-2014 at 11:12 AM. Reason: corrected obd2 PTE ecu code
B16_ek
19
04-21-2009 04:18 PM
ekhatchturbo
08-30-2007 11:32 AM
VTC_CiViC
05-17-2004 08:45 AM
