Wheel Bearing replacement
Old 03-24-2003, 06:07 AM
RedHatch.eh's Avatar
Default Wheel Bearing replacement
How hard is it to replace a wheel bearing on my car? Anybody have a step-by-step?
Old 03-24-2003, 06:09 AM
Loco Honkey's Avatar
Default Re: Wheel Bearing replacement (RedHatch.eh)
Not too bad. Buy a manual and if it's still not clear, come back and ask questions.
Old 03-24-2003, 06:10 AM
Mr. Badwrench
boostedcivicsir's Avatar
remove wheel
remove caliper and rotor
remove axle nut
remove spindle
using a clam shell, bearing separator, press the hub out of the bearing
remove the snap ring under the hub
then press the bearing out the front
oh yeah i forgot. install in reverse order and remember the snap ring.
basically if you dint have a bearing separator, and a press,
it is really hard. not impossible, but it is not fun.
if you are new to this, it is much easier to let someone who has done it, take care of it for you.
[Modified by boostedcivicsir, 3:11 PM 3/24/2003]
Old 03-24-2003, 06:13 AM
Default Re: Wheel Bearing replacement (boostedcivicsir)
I still say go buy a manual. I have no pity for someone who works on a car without a manual and then comes here and whines about ******* it up.
Old 03-24-2003, 06:21 AM
Default Re: Wheel Bearing replacement (Loco Honkey)
When I work on my motorcycle, I always refer to the manual. Not too worry, I'll get a manual as soon as the have one in stock. I tried finding one this weekend but all the local shops were all out. What gives? Anyhow, thanks for the info. I wanted to know if there was anything special I needed, and it seems I do. I will probably just go see my buddy to have it done, as I don't have all the requied tools. He has about $60G in Snap-on tools so I'll leave it to him and buy him a 24 of Budweiser :D
Thanks again.
Old 03-24-2003, 06:39 AM
piscorpio's Avatar
What about someone like me, who has a manual, uses it while working on car, and still comes to whine about ******* up.
Old 03-25-2003, 02:13 PM
Default Re: Wheel Bearing replacement (piscorpio)
That's different, because you're using the manual and still have questions. A good 95% of the R&R questions I see in here can be found in a simple $13 Haynes Manual.
Old 08-11-2004, 05:27 PM
Go Tigers!
Bense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loco Honkey &raquo;</TD></TR><TR><TD CLASS="quote">I still say go buy a manual. I have no pity for someone who works on a car without a manual and then comes here and whines about ******* it up.</TD></TR></TABLE>
i have the haynes manual and it says "take it to a professional shop" to replace the front wheel bearings.
so, can anyone point me to a good write up?
roterx7
30
03-13-2015 05:40 AM
kg98921byrams
11-10-2007 02:55 PM
brospeed2001
08-05-2003 06:05 PM
96Prelord
05-05-2003 03:05 AM
GeeSeeR
08-08-2001 03:32 PM
Quick Reply: Wheel Bearing replacement
