Wheel Bearing
Old 07-25-2004, 10:26 PM
crashN2u's Avatar
Default Wheel Bearing
How do you know your wheel bearing is going bad? What's the sound it makes? How do I check if it's going bad?
Old 07-25-2004, 10:50 PM
slammed_93_hatch's Avatar
Default Re: Wheel Bearing (crashN2u)
jack your car up and put on hand on one side of the tire and the other hand oppisite it, then push and pull if you have movement your ***** bad.
as for the sound i don't know and wouldn't want to find out,
crashN2u's Avatar
Bump. I just started hearing this weird humming noise that seems to be coming from the driver's side when my window is down.
Old 07-25-2004, 11:50 PM
BatuKing's Avatar
when you take a turn the noise should be louder.. it will sound like a grinding noise
Old 07-29-2004, 02:27 AM
SPOON_FED_DC_2's Avatar
if your wheel bearing is bad it will sound like you have some 35" super swapmer boggers when ur going down the road
Old 07-29-2004, 04:39 AM
Sijray21's Avatar
Default Re: Wheel Bearing (SPOON_FED_DC_2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOON_FED_DC_2 &raquo;</TD></TR><TR><TD CLASS="quote">if your wheel bearing is bad it will sound like you have some 35" super swapmer boggers when ur going down the road</TD></TR></TABLE>
or if you have azenis on with stock exhast and muted stereo
if you start turning and you hear a grinding noise, and check it when the car is on the ground, just try to wiggle the wheel, you'll be able to tell if it's going bad
i don't have a press to work with, but how much would this cost to get fixed. i know i'll probably need to replace my passenger-side front soon
Old 07-29-2004, 05:33 AM
H-T Order of Merit
TouringAccord's Avatar
Default Re: Wheel Bearing (Sijray21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sijray21 &raquo;</TD></TR><TR><TD CLASS="quote">
i don't have a press to work with, but how much would this cost to get fixed. i know i'll probably need to replace my passenger-side front soon</TD></TR></TABLE>
When I replaced my brake rotors and bearings on my Accord which is hub-over-rotor making it a PITA I just took the knuckle assembly to a machine shop and had them disassembly everything and reassemble it all. Tokk them like an hour and cost me 25 a side. Well worth it IMO. But if you take just your bearing/hub assembly in with the new bearing it'll probably be much cheaper since they don't have to do so much work.
Old 07-29-2004, 05:57 AM
nahledge 7's Avatar
its should be making a thoomp, thoomp, thoomp sound when u are driving and pick up as u gain speed.
Old 07-29-2004, 06:29 AM
Dangydang's Avatar
Yup, it sounds like a very loud howling tire sound. I had to blast the stereo to drone out the sound on the highway. Just had both of my fronts changed about a month ago...no more annoying sound and no more looseplay in the steering.
MrDomino
05-26-2008 12:11 PM
91EF_Si
11
03-13-2008 03:45 AM
WEEZY034
04-05-2007 02:59 PM
drewbie
05-09-2004 12:31 PM
Padronis
05-02-2002 05:40 PM
Quick Reply: Wheel Bearing
