wavering idle
Old 02-03-2007, 06:02 PM
jefftron's Avatar
Default wavering idle
i have a 93 civic hatch with a d15y. i got the car about 20days ago and i found out that the when idling wavers between 1000 rpms and 1500 rpms. the car is not turboed.
at 2200 rpms the needle starts to waver rapidly, almost as if turboed. everything is hooked up and there is no check engine light.
some1 please explain wats going on and how i could fix this problem. thanx
Old 02-04-2007, 05:42 PM
groundzerocivic's Avatar
Default Re: wavering idle (jefftron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jefftron &raquo;</TD></TR><TR><TD CLASS="quote">i have a 93 civic hatch with a d15y. i got the car about 20days ago and i found out that the when idling wavers between 1000 rpms and 1500 rpms. the car is not turboed.
some1 please explain wats going on and how i could fix this problem. thanx</TD></TR></TABLE>
idle air control valve is dirty.......
its located on the back of the intake manifold by the throttle body.....
2-12mm bolts and 2 hose clamps hold that bad boy on..
remove it and spray some brake cleaner of choke & carb clearer through it, let it dry and reinstall it......
Old 02-10-2007, 05:38 PM
broski's Avatar
jeff, you need to re paint your car. then it will idle correctly...
and learn to use search!
haha
let's work on my car tomorrow. and adjust my rear coils. and figure out what that clunking noise is
Ronnoc74
26
04-14-2011 05:35 PM
flyerhky11
02-16-2006 08:10 AM
Mr si99
05-05-2005 08:31 PM
dvcart106
08-06-2003 08:41 AM
sr20seth
05-31-2003 08:24 AM
Quick Reply: wavering idle
