usdm b16a2 vacuum hose diagram for 96 civic cx??? HELP!
Need to know the vacuum hose diagram for a '00 b16a2 onto my 96 civic cx. is there anything there that I have to plug? I'm having some problems with my idle and my mechanic says that its a vaccum leak. I'm trying to pinpoint where my hoses go first, which ones I can plug. I don't have power steering, a/c, cruise, etc.
Currently running obd1 p30 ecu via jumper harness obd2a-obd1.
I'm also going to do a tune up, which parts should I replace? I've already changed my spark plugs to ngk g-power and gapped them to spec.
My mechanic also noted that my timing is not consistent and he had to advance timing 9 degrees so that it would run right, for now. as the timing sometimes moves back and forth from the actual line.
Any help would be appreciated!
Re: usdm b16a2 vacuum hose diagram for 96 civic cx??? HELP! (pinoyboy204)
also, i sometimes get a CEL when i reach over 3000 rpm. first it kinda hesitates a bit then the light comes on. could that mean o2 sensor??
From what I can remember when I did my swap in my 96 CX hatch, the only place i had to bplug off was a on the back of the manifold, as your facing it, on the back. Ill see if I can find a picture.
Also you may change your distributor cap and rotor as part of the tune up, and plug wires too.
Modified by 93Civac at 4:01 AM 6/16/2006
Re: (93Civac)
This was the olny place I had to plug off for vacuum. This is not the exact intake manifold but the part is in the same place, i circled it in red. Hope it helps some. Oh and I believe this is for the cruise control so that may be your leak ?
Re: (93Civac)
is it the one that has an attachment to a what looks to be an EGR valve and sensor plugged into it w/ the vacuum hose? i can take it off???
