thinking of running acetone if my car dont pass emissions
Old 05-07-2010, 06:06 AM
Juans_MX3's Avatar
Default thinking of running acetone if my car dont pass emissions
I have heard that people recommend 1oz per 10 gallons. That acetone reduces HydroCarbons (which I am failing at idle).
Yes, I have everything tuned up on the car (PCV, oil, oil filter, air filter, NGK plugs n wires, cap and rotor). If I still dont pass im going to change out the CAT.
Honda Civic EX's take 88 Octane fuel right?
Anyone here successfully try this to pass emissions?
Old 05-07-2010, 07:28 AM
b20hatchek's Avatar
Default Re: thinking of running acetone if my car dont pass emissions
no we all run 91-93 whatever the highest is where you live, but ive heard ppl run a lower octane to pass the emissions but id run seafoam straight to the motor and that'll burn off ALOT of carbon off the pistons and what not, but i live in texas and we dont have those kinds of emission test, ive heard of ppl etting them passed in other states too just so they have a passing sticker on their car
Old 05-07-2010, 09:43 AM
97twodoor's Avatar
What's your ignition timing at? Also how are your NOx readings on the driving test? How bad is it failing at idle?
Old 05-07-2010, 11:33 AM
Juans_MX3's Avatar
My readings:
TEST 1: Used spark plug wires with unkown mileage, Motorcraft brand spark plugs, 10W-30 synthetic high mileage oil change with filter, CAI. 88 Octane fuel
High Speed Test
HC (ppm)
171/220 (pass)
CO%
.67/1.20 (pass)
CO2 %
14.0 @ 2526RPMs
Idle Test:
HC (ppm)
509/220 (fail)
CO%
.71/.120 (pass)
CO2 %
13.0 @ 779RPMs
TEST 2: after putting on my barely ever used 88 Honda CRX HF duralast spark plug wires from like 2 years ago that were laying around. Also, after putting the stock air intake with a new filter. 91 Octane fuel
High Speed Test
HC (ppm)
182/220 (pass)
CO%
.62/1.20 (pass)
CO2 %
13.5 @ 2530RPMs
Idle Test:
HC (ppm)
595/220 (fail)
CO%
.71/.120 (pass)
CO2 %
12.6 @ 739RPMs
Yea, its failing pretty bad a idle HC...
Old 05-07-2010, 11:34 AM
Juans_MX3's Avatar
I have tried running 91 and the car got "engine ping" from pre-detonation.
Timing was already adjusted and correct.
SI_Ro
12-21-2011 10:36 AM
dem0nk1d
07-07-2006 11:11 AM
vtec25
03-22-2006 07:34 PM
Spence
07-13-2004 07:47 PM
cueballsi
06-09-2004 08:16 PM
Quick Reply: thinking of running acetone if my car dont pass emissions
