tar removal sound deadening material stripping
Re: tar removal sound deadening material stripping (all stock)
the two ways i've had experience with is a heat gun and dry ice. to get it all out, depending on how old the stuff is, you'll probably have to use both methods. heat gun is kinda obvious. you heat the stuff up and scrape it off. for dry ice (you should be able to get it at grocery stores) you let the dry ice sit on the S.D material for a little while and then use a mallet or hammer to pound on material to break it up after it's frozen. just be careful not to use TOO much force when you're breaking it up or you'll dent something. also, dry ice is VERY VERY cold, so it's a good idea to wear gloves while handling it so you don't get freezer burn.
I haven't gone very far into lightening up my car yet, so where is the tar and sound deadening material all located at, and around how much does it weight?
Re: tar removal sound deadening material stripping (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 »</TD></TR><TR><TD CLASS="quote">I haven't gone very far into lightening up my car yet, so where is the tar and sound deadening material all located at, and around how much does it weight?</TD></TR></TABLE>
i've heard it's about 35 lbs when u include the foam for the firewall mat.
get a can of dust off, computer cleaner chet.... that stuff you get high off.... hold the can upside down and spray the crap out of that crap... it will freeze and crack by itself....
Re: (acura_typer)
i removed all of mine with a heat gun and a scraper. the tar is all inside the trunk of your car and under your carpet. But if you dont have a race car i dont think its worth the trouble. I wouldnt do it again
Re: (GReddy SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GReddy SI »</TD></TR><TR><TD CLASS="quote">
like this ?
holy, drooooool
thats clean!!
like this ?
holy, drooooool
thats clean!!
Re: (96 SOHC VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 SOHC VTEC »</TD></TR><TR><TD CLASS="quote">Can you just use a hammer and chissle to get rid of the sound deadening?</TD></TR></TABLE>
You could do it that way it just takes alot longer
Re: (gambit33)
thats because you did it wrong. Use dry ice and it will take an hour. leave it on until it all pops and you can break it off with your hands. I use a putty knife to get under it and pry up, not to scrape. Use deadblow hammer to knock it loose too.
Re: (GReddy SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GReddy SI »</TD></TR><TR><TD CLASS="quote">hehehe mines didnt come with tar ,, its a 92 VX </TD></TR></TABLE>
woohoo, thats right suckas! Enjoy your dry ice!
Sorry I had to gloat, but it's the only thing my car is good for.
Re: (all stock)
All u need is a hammer paint scraper and patience. first u cut the tar patch u are working on in a pie configureation. then star at the edge of the tar and hammer the paint scrapper under it like your going to flip a pan cake and it comes up with no problems. NOTE do this in a shaded area and dont do it on a car that has been in the sun for a long wile u want the tar cold or at room temp
Re: (underrated99si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underrated99si »</TD></TR><TR><TD CLASS="quote">NOTE do this in a shaded area and dont do it on a car that has been in the sun for a long wile u want the tar cold or at room temp</TD></TR></TABLE>
Midnight it is.
Midnight it is.
Steve91
18
05-29-2002 06:38 AM
