speedometer not working
Old 07-28-2013, 02:53 PM
DarkGriffin3156's Avatar
Icon6 speedometer not working
Hey,
I just started driving my parents old '93 Del Sol. Right now one of my biggest problems is that the speedometer is not working. Any suggestions on how to fix it.
Old 07-28-2013, 03:50 PM
black97civic's Avatar
Default Re: speedometer not working
Check the sensor its located on top of the tranny. Google search the part to see what it looks like. Check and make sure the wires are intact and the plug is good.
Old 07-28-2013, 05:54 PM
crazyhouse2011's Avatar
Scan for codes. If you get a code 17, replace your Vehicle Speed Sensor. A VSS for my D16 was like 20 bucks. Pop it in yourself and you save another 80 from the stealership. here's what it looks like out of the car:
And here it is on the top of the tranny:
Old 07-29-2013, 01:33 PM
redcoats1976's Avatar
it just doesnt work or is innaccurate?after replacing my speed sensor with no results(mine would read from 5-20 mph less,and you never knew what to believe)i replaced the instrument cluster.that solved the problem.
Old 08-10-2014, 06:00 PM
I replaced the VSS but the speedometer still doesn't work, but the odometer works fine.
DC2man
03-03-2008 07:01 PM
silentblackhat
12-25-2005 05:29 PM
bg-33p
02-12-2005 10:33 PM
SPOON_FED_DC_2
07-29-2004 01:13 AM
vtekthis
03-25-2004 10:39 PM
Quick Reply: speedometer not working
