Shaking on the Front Wheel?
Old 06-04-2007, 01:16 AM
DAP97SI's Avatar
Default Shaking on the Front Wheel?
I have a 97 Civic Hatch and when I am doing over 70 mph the front left wheel starts to shake and the steering wheel also. What can the problem be? Bad alignment or what?
Old 06-04-2007, 02:31 AM
john666's Avatar
Default Re: Shaking on the Front Wheel? (DAP97SI)
well..im guessing u say the front left because someone saw it shaking while u were driving... im guessing a bent rim perhaps ? and maybe a alignment is needed. (im guessing someone hit the curb hard enough to bend your rim and mess ur alignment up, just a guess tho)
Old 06-04-2007, 06:21 AM
gtlaw1's Avatar
wheel is out of balance
Old 06-04-2007, 10:22 AM
DAP97SI's Avatar
Well, no one saw the wheel shaking, but you can feel the vibration from inside the car. I thought it was an alignment problem but I am not sure.
Old 06-04-2007, 10:31 AM
BubblegumTate's Avatar
Default Re: (DAP97SI)
Go to a tire shop and have them check and rebalance the wheels. My guess is it is an unbalanced wheel.
Old 06-04-2007, 10:32 AM
Ek Forever y0!
Libertariat's Avatar
It could be a number of things.
Wheel balance, wheel bearing, axle.
Jack your car up and leave it in neutral. Sprin your front tire manually back and forth, if you hear a grinding noise then it's your wheel bearing.
Clicking could be joints/axles.
Old 06-04-2007, 10:34 AM
instructor74's Avatar
it could be a number of things. the wheel could just need to be rebalanced, could be a bent rim or bad tire. These are all things you can easily have checked when you have the tire balanced. You could have a bad/ warped brake rotor or caliper that is hanging up. Do a runout test on the brake rotor to tell if it is warped make sure the brake calipers are moving freely if not repair or replace any damaged comp. This is what I found on mine after countless places telling me the rotors were bad or caliper wasn't working. Check for play in the ball joints, tie rods inner/outer again replace damaged and have the car aligned good luck and let us know what you find
Old 06-04-2007, 11:14 AM
Ion22's Avatar
It could be a lot of camber wear on the inside of your tire that was what it was for me just reach your hand around and feel the inside of your tire and if it is smooth get new tires.
Old 06-04-2007, 11:36 AM
hatchling37's Avatar
Default Re: (Ion22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ion22 &raquo;</TD></TR><TR><TD CLASS="quote">...just reach your hand around and feel the inside of your tire and if it is smooth get new tires.</TD></TR></TABLE>Awesome.
Old 06-04-2007, 11:40 AM
Ek Forever y0!
Default Re: (hatchling37)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ion22 &raquo;</TD></TR><TR><TD CLASS="quote">It could be a lot of camber wear on the inside of your tire that was what it was for me just reach your hand around and feel the inside of your tire and if it is smooth get new tires.</TD></TR></TABLE>
You mean get new tires AND correct your camber.
Though camber is usually only a problem on drops more than 2"
Old 06-04-2007, 11:44 AM
EG-lowrider's Avatar
check the tie rod end.
Old 06-04-2007, 12:47 PM
hondamark35's Avatar
shaking at a certain speed (esp. right around or above 70) is out of balance. the bent rim is the second to that. but usually a bent rim, if it's bad is noticable at slower speeds as well. also if you have aftermarket wheels or anything other than honda or acura wheels you may need hub spacers. figured that out the hard way on a customers car. the lugs can only do so much to center the wheel on the hub.
Old 06-04-2007, 01:51 PM
Not now Chief, I'm in the F'n zone!
Code's Avatar
Balance your tires.
soclean1k_JDM
Suspension & Brakes
11
03-23-2010 09:40 PM
arren123
06-07-2006 05:11 AM
uneek4dr
04-24-2006 01:12 AM
ShadyBAB
08-08-2005 01:49 PM
OneThirtyEight
10-30-2001 06:03 PM
Quick Reply: Shaking on the Front Wheel?
