Separate Wire for Tach to work
Old 05-27-2010, 11:14 AM
Dekorum's Avatar
Default Separate Wire for Tach to work
Does anybody know why you have to run a separate wire to make the tachometer work on certain swaps? I am sure it has to do with the combination of body harness + engine harness, but I want to know for sure. I would like to know why I had to run a wire to my distributor plug from one of the connectors on the driverside shock tower for my tach to work after my swap
Old 05-27-2010, 11:22 AM
EJeff8's Avatar
Default Re: Separate Wire for Tach to work
Well, you need a wire for the needle to sweep, a wire for the information, and a ground of course.
Old 05-27-2010, 11:25 AM
Dekorum's Avatar
Yeah, its just one extra wire you have to run on certain swaps. I am just wondering why ..
Old 05-27-2010, 11:27 AM
EJeff8's Avatar
Could be a pin change.
Old 05-27-2010, 11:32 AM
Former Moderator
B18C5-EH2's Avatar
Perhaps the lead on the ignitor inside the distributor that's off to the side (this is the tach signal) is loose or off?
Old 05-27-2010, 11:53 AM
CivicSpoon's Avatar
'99-'00 Civics (excluding the Si and HX) have Engine Speed Output (signal for the tach) run off of the ECU, rather than the distributor. Where they have the 8-wire plug rather than a 9-wire plug. Does any of that pertain to the swap you're doing?
Maybe you should be a little more specific about what car you have, what harnesses & ECU you're using, and what engine you're putting in.
Old 05-27-2010, 11:59 AM
Former Moderator
B18C5-EH2's Avatar
He has a 1992 Civic Si HB with JDM B18C (Type R) and what is supposed to be a 1997 USDM Integra GS-R engine harness. Currently he's running a jumper harness and a JDM P73 ECU.
Old 05-27-2010, 04:59 PM
Dekorum's Avatar
^^ Correct.
Except the engine harness I am using is supposed to be a USDM Type R harness. Not sure of the year though!
Old 05-28-2010, 02:41 PM
Dekorum's Avatar
Any one else have any ideas?
Old 05-28-2010, 02:44 PM
Gunmetal_B20_Hatch's Avatar
light blue wire between DS shock tower and firewall?
Old 05-28-2010, 02:48 PM
Dekorum's Avatar
Right, I believe that is supposed to be it. I am wondering WHY it did not control my tach once I dropped in the OBD2 Type R USDM harness like plug and play. I had to run an extra wire directly from the DS shock tower connector to the distributor connector. My tach works perfectly now. I am just wondering WHY I had to do it, when I have heard of others just using an OBD2a harness in an EG swap and it works the tach plug and play.
Old 05-28-2010, 02:54 PM
I would go with the above post by B18C5-EH2 about the difference in 8 and 9-pin plugs.
Old 05-28-2010, 04:01 PM
Dekorum's Avatar
Well CivicSpoon said that about 99-00 Civics. I don't have anything from a 99-00 Civic in my setup..
Old 05-28-2010, 05:29 PM
CivicSpoon's Avatar
Maybe something in this thread has something to do with it?
https://honda-tech.com/forums/acura-integra-type-r-8/jdm-itr-ecu-tach-signal-different-than-usdm-2118063/
The only other thing I can find from a search is a LOT of people having the same issue. But I haven't seen a single answer as to why. I wish I had a copy of the '98-'01 Integra ETM to check it out myself.
Old 05-28-2010, 05:42 PM
Dekorum's Avatar
Hmm.. well I was running a P28 at first, and my tach still didn't work. So this may mean that the USDM Type R engine harness I bought from a friend is a 2000-2001 one? I know the engine is a 96 JDM ITR.
Old 05-28-2010, 05:43 PM
Dekorum's Avatar
Wait, wouldn't there be a noticeable difference in the 97-98 and the 00-01 Type R engine harness? If I knew what they were, I would go out and check if I see any of them on my harness.
Old 05-28-2010, 07:27 PM
CivicSpoon's Avatar
We didn't get OBD2A ITRs over here in N. America; the Type R's were only sold here in '00-'01 (OBD2B). There would be differences between the models, which could narrow it down. The GS-R would have wiring for the IAB and the LS wouldn't have wiring for VTEC. But as for OBD2A vs OBD2B harness differences, I don't know. Seems this may be one of those "little" things that the Honda community may not have a definite answer for.
Old 05-28-2010, 07:31 PM
Dekorum's Avatar
Haha, maybe I can't get a definite answer. But I thought I would try.
Also, there definitely WAS an OBD2A ITR in North America. 1997-1998 did exist in America. Japan got the 1996 which we didn't. And the 1999 did not exist anywhere.
Old 05-29-2010, 05:43 PM
CivicSpoon's Avatar
OMG, how did I not know that... I would have put $ on the fact that the Type R came here in '00. I don't know why I thought that.
Old 05-29-2010, 07:42 PM
Dekorum's Avatar
Haha, you mean 99. Cause they did come here in '00!
epingquian
03-29-2018 08:29 AM
4dooreg-k
11
06-23-2006 12:50 PM
1sikhatch
11
03-14-2006 09:19 PM
YellowCRXSi
07-12-2004 09:55 PM
serious
01-22-2003 11:21 PM
Quick Reply: Separate Wire for Tach to work
