Running too rich? Minor backfiring & gas coming out of the exhaust?
Old 06-01-2004, 07:37 AM
trooper0641's Avatar
Default Running too rich? Minor backfiring & gas coming out of the exhaust?
Is this running either too rich or too lean? How can I fix this problem?
Old 06-01-2004, 07:52 AM
CBRF4i's Avatar
Default Re: Running too rich? Minor backfiring & gas coming out of the exhaust? (trooper0641)
Could be anything from a fuel injector stuck open or just an o2. Check both.
Old 06-01-2004, 08:04 AM
bbarbulo's Avatar
mods, chip, exhaust... list all relevant info
Old 06-01-2004, 08:08 AM
Default Re: (bbarbulo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bbarbulo &raquo;</TD></TR><TR><TD CLASS="quote">mods, chip, exhaust... list all relevant info</TD></TR></TABLE>
Lets see...
1992 Civic CX
aem cold air intake
dc 4-1 header
2.5" Magnaflow highflow cat /22" resonator/ oval exhaust
skunk2 cam gear / 2 degrees advance
ngk wires w/ ngk iridiums
stock p28 ecu
Old 06-01-2004, 10:00 AM
EKB18BPR3's Avatar
Default Re: (trooper0641)
"2 degrees advance"
maybe...
Old 06-01-2004, 12:08 PM
Default Re: (98B00STED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98B00STED &raquo;</TD></TR><TR><TD CLASS="quote">"2 degrees advance"
maybe... </TD></TR></TABLE>
lmao
Old 06-01-2004, 04:19 PM
ttt
Old 06-11-2004, 02:55 PM
brockscivic's Avatar
i have the same problem with my 1992 LX, its got a 95 d15b7 with I/E and new injectors and regulator and it still backfires and i have gas coming out. I would also like to find the cure for this...
Old 06-11-2004, 03:06 PM
99blackcivicSi's Avatar
Default Re: (brockscivic)
are you gettin ample spark? did you gap the plugs when you bought them or just threw them in? see if your gettins enough spark and your plugs are good. Than start checking to see if injectors are pulsing correctly (use noid light) then get back to me
Old 06-11-2004, 04:55 PM
Global Moderator
Jimmy's Avatar
Do you have a cat?
My car tends to do it a little after down shifting.
It seems normal..because my d16z6 runs strong.
I also notice this on most car's with just exhaust.
Just don't bother with it UNLESS its ''real bad''
Old 06-11-2004, 06:23 PM
SolObsession's Avatar
Default Re: (Jimmy)
When I only had an exhaust on my car (hated those days), if I was coasting down a hill and I lightly would tap on the gas it would backfire.
Old 06-11-2004, 07:52 PM
Dreamworx's Avatar
Default firing
Well i dont know why you would complain about that... I cant make it do the little popping in the exhaust if i barley rest my foot on the gas pedal... i like the way it sounds... might make me a dork but it reminds me of my rx7... let off the gas at night get the spitting and sputtering and it would throw flames...
Peace
Old 06-11-2004, 09:11 PM
madtownhonda's Avatar
Default Re: firing (MinesBiggerThanYours)
Mine grumbles like that when I decellerate. I'm pretty sure it's just fuel that is burning up in the exhaust due to running rich. That and a combination of the injectors not closing fast enough is probably the cause. Sounds pretty bad *** though.
MADBADGER
Honda S2000
05-27-2008 05:47 PM
rodimus
17
08-07-2005 04:20 PM
jeffb006
03-26-2004 08:49 PM
hYpE-R-29
06-13-2003 05:55 AM
TheAntiRice
06-10-2003 09:16 PM
Quick Reply: Running too rich? Minor backfiring & gas coming out of the exhaust?
