Question on Loose shifter
Old 04-06-2010, 11:42 AM
GuCBlackEk's Avatar
Default Question on Loose shifter
I have a question on my shifter. It is very loose, meaning when it's in gear it seems to be loose. does this mean that the bushings will need to be replaced?
Old 04-06-2010, 11:45 AM
ballisticej1's Avatar
Default Re: Question on Loose shifter
Yeah, you're most likely talking about the shifter bushings being all worn out, which will cause an extra loose shifter feel.
Old 04-06-2010, 11:53 AM
GuCBlackEk's Avatar
okay. thanks. that's what I thought.
Old 04-06-2010, 12:31 PM
cleansi's Avatar
usually the bushings bad even in some civics ive seen with 250k miles alot of the time its just the hardware ie the 1 bolt that goes through the ball part of the shifter is corroded or just needs to tourqed a little, i have energy shift linkage bushings and feels like oem its usually that bolt
Old 04-06-2010, 04:06 PM
GuCBlackEk's Avatar
I see, I planned on buying the energy bushings also.
Old 04-07-2010, 03:28 PM
David12's Avatar
the energy bushings should fix ur problem
hillbillycivic
03-13-2013 08:14 PM
elmalouno
05-02-2008 08:37 AM
MiamiEgGSr
11-04-2007 04:37 PM
eluder33
11-20-2004 03:05 PM
tolowhb
12-29-2002 05:11 PM
Quick Reply: Question on Loose shifter
