PUMPING BETTER FUEL
Old 05-26-2004, 09:33 AM
Kaisar's Avatar
Default PUMPING BETTER FUEL
I have a 96' Civic Coupe with a b18c5 swap. I rebuilt the head and block and installed the drag bolt-on turbo kit(stage 2). My first question is with the hp I have, will a stage two clutch kit be enough, or do I need more. If so, what company do you suggest?
The second question is about aftermarket fuel pumps. I'm a little naive in this area, so that's why I'm writing sending this out. what brand will work best with my setup? And if I change the fuel pump, should I change the fuel lines as well? Thanks
Old 05-26-2004, 09:38 AM
Spade's Avatar
Default Re: PUMPING BETTER FUEL (Kaisar)
I would suggest a stronger clutch. Your not going to be driving normal obviously.
And
Aftermarket pumps are all Walbro they just get re-badged
You will not need to change your fuel lines.
madcrx69
08-15-2017 09:26 PM
MShonda
01-06-2010 03:16 AM
BLU CIVIC
10-29-2008 07:47 PM
jwcardy
04-04-2004 02:53 PM
Toad
01-03-2003 10:10 AM
Quick Reply: PUMPING BETTER FUEL
