96 Honda Civic CX Running Rough and Need Help
My 96 Honda Civic CX is having some minor problems, on hot humid days, after the car warms up, everytimg i come to a stop, the car will stall. that night when it cools off the athe humidity drops the car will run fine, do you think this is an idle problem, or does it need plugs, wires, distributor cap, and rotor, or what else do you think it could be?
Re: 96 Honda Civic CX Running Rough and Need Help (TODAeg6)
it does not bog before it stalls, when it stall it is just like you shut the car off. I did have a check engine light on, and the code read Bank 1 running lean, but to this day noone has been able to tell me what to do to correct that.
Re: (H22BuiltEGhatch)
i havent seen a fuel pump partially quit working though, i have only seen ones that work, or dont...can a fuel pump pump less fuel?
Re: 96 Honda Civic CX Running Rough and Need Help (beatercivicCX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beatercivicCX »</TD></TR><TR><TD CLASS="quote">i will be giving this car a much needed tune up, we shall see what happens.</TD></TR></TABLE>
Might just as well do the your main grounds while you're at it.
What is your mileage looking like?
Cap, rotor, plugs, wires, air filter, fuel filter and an oil change is a good place to start.
What about a valve adjustment?
If you've got over 75k on the stock O2 sensor, it'd be a good time to replace it as well. O2's only last so long and on my stock 99 hatch (D16Y7) I begin to notice a drop in power and gas mileage when approaching the 75k mark.
As JRI94 mentioned, cleaning the grounds would be wise as well.
i have a 96 cx also and my lasted till little over 390,000. when my timing was way off after replacing the engine it would cause it die once it was warmed up
Re: 96 Honda Civic CX Running Rough and Need Help (biggmike2)
it doesnt do it all the time though, just under certain conditions..., i am thinking a tune up shoud stop it completely or cut it way down.
slim420rg
08-24-2010 07:20 PM
Jawad.
09-04-2003 12:19 PM
