problems with swap in new car.
Old 04-27-2011, 04:21 PM
sega2010's Avatar
Default problems with swap in new car.
Just got a 1998 ek. Its got a d16z6 swapped in it from a 93 del sol. My problem is this:
The shittiest wiring I've ever seen. The whole harness is f**ked up. The ecu is the p28 for the motor. My question is, could I just buy the engine harness for the d16z6 and the ecu and just have the car obd1 or should I get the harness for the car itself and keep it obd2. Cause right now I have a check engine light and when I hook a scan tool to the data link it reads no link and I tried doing it obd1 way but it doesn't work either.
Old 04-27-2011, 05:02 PM
Tyla12's Avatar
Default Re: problems with swap in new car.
just use ur p28 ecu and wire up vtec
Old 04-27-2011, 05:09 PM
The Grumpiest
grumblemarc's Avatar
So you bought it that way? And you're bitching about it? Are you sure it's a P28 cause that's the correct ECU for that engine.?
Old 04-27-2011, 05:21 PM
sega2010's Avatar
Yes I bought it that way. I didn't know the wiring job was so shitty. All I want is to clean it up cause it's a giant mess.
randil86
03-22-2017 06:23 PM
e0325
07-09-2014 05:14 PM
glennsek9
02-06-2012 11:47 AM
JST1CAM
01-24-2006 04:43 PM
ITRnorway
05-11-2005 09:45 AM
Quick Reply: problems with swap in new car.
