overfilled clutch master cylinder reservoir
Old 06-18-2011, 11:49 AM
gen2tegboi's Avatar
Default overfilled clutch master cylinder reservoir
I just picked up my car from the mechanic after getting the clutch master cylinder replaced. I noticed the reservoir is way overfilled, is this bad? what can it cause? the mechanic insisted that it was ok, but I want to make sure this is correct.
thanks for any input in advance.
Old 06-18-2011, 11:52 AM
NACvicSi's Avatar
Default Re: overfilled clutch master cylinder reservoir
It should be fine considering it won't use anymore than it needs. How can it be way over filled there isn't much room in there anyway. Just take out the amount it's over filled by and call it a day.
Old 06-18-2011, 12:08 PM
The Grumpiest
grumblemarc's Avatar
Don't see how it's possible to be overfilled.
Old 06-18-2011, 12:11 PM
gen2tegboi's Avatar
its full up to the cap, which is actually about one inch above the max line. I just wanted to make sure what the mechanic said was correct.
to take out the amount overfill, just open nipple on the slave cylinder to drain the extra? or siphon it out?
thanks
Old 06-18-2011, 12:18 PM
Master Detailer
98civdx's Avatar
Open it, and have someone pump the petal.
The Grumpiest
Leave it alone. Is it causing performance issues?
Old 06-18-2011, 12:31 PM
gen2tegboi's Avatar
not really, at least not yet. I have only driven it three miles to my home. I thought the min, max marks where there for a reason. which is why I worry there could be performance issues later on. Either way, I'll head out to my parents garage tomorrow to drain some out, and keep it on specs
Old 06-18-2011, 03:12 PM
95EG2's Avatar
will be fine... if ur worried have someone hold the clutch pedal down and open the slave cylinder bleeder will takes some fluid out
Old 06-18-2011, 03:43 PM
Two Piece
Go_Race_Your_Self's Avatar
Nothing to worry about. If it bugs you that much, take a straw and suck some out. Just dont drink it. Its not kool-aid...
Old 06-18-2011, 05:17 PM
NACvicSi's Avatar
I don't know. It has a nice smoked flavor I've come akin too. Prestone taste the best.
Old 06-18-2011, 05:26 PM
ktsciv93's Avatar
bleed ur clutch line till the fluid level reaches the marks. can't hurt anything...
Old 06-18-2011, 06:34 PM
Slacker93eg's Avatar
Stick a paper towel in there and let it soak some up.. or leave it, it won't hurt
ca86108
05-06-2010 06:54 AM
R81_DC2
08-14-2009 08:54 PM
S2k Hybrid
03-15-2007 10:36 PM
siregcivic
10-16-2005 07:55 PM
Quick Reply: overfilled clutch master cylinder reservoir
