Oil light flashing
Old 03-03-2014, 06:03 AM
Aaronw93's Avatar
Default Oil light flashing
So I have a 92 Honda civic with a d16y8 in it and the other day I was driving it and my oil light came on when I stopped and started to flash a lil but it went off when I took off and would only come back on when I stopped and the car had oil in it what could this be?
Old 03-03-2014, 06:16 AM
arizona del sol's Avatar
Default Re: Oil light flashing
Oil pressure decreases when engine RPM decreases. So when you're sitting at a stop, or at idle, your oil pressure drops. Apparently its dropping enough to set off the idiot light. You need to have the pressure checked with a gauge to know exactly what the pressure is, both at idle and at higher RPM.
Old 03-03-2014, 06:23 AM
Aaronw93's Avatar
Ok someone told me tht it could e the oil pressure sensor is tht possible?
Old 03-03-2014, 06:33 AM
B_Swapped93's Avatar
agree^^
not too likely but a possibility non the less, check pressure at idle how many miles on the engine ?
Old 03-03-2014, 06:45 AM
Aaronw93's Avatar
Ok and idk the exact mileage cuz I done a motor swap but it's about 200 and something thousand
Old 03-03-2014, 06:48 AM
Aaronw93's Avatar
And how can u check to see if the oil pump is goin bad
Old 03-03-2014, 08:32 AM
apexi_rsx's Avatar
how long since ur last oil change? the idiot light don't come on unless ur under 3psi or pressure.
Old 03-03-2014, 01:55 PM
Aaronw93's Avatar
It's been about a month since my last oil change
Old 03-03-2014, 02:07 PM
Sebba's Avatar
You hook up an oil pressure gauge right after the pump.
If your car has high mileage, I'm betting this is oil pressure loss due to increased clearance in the bearings.
Old 03-03-2014, 02:50 PM
I never narc'd on nobody!
NotARaCist's Avatar
OP, did you even bother checking how much oil you have in the car? That is the absolute first thing you should do whenever that light comes on. Turn over, turn the car off immediately, and check your oil level. It's a dummy light - if it comes on, your motor is going to be very damaged, very quickly.
Old 03-03-2014, 03:48 PM
Resident Gearhead
BryanM.'s Avatar
Yes I have had this happen before and it was the oil pressure sensor above the oil filter that was bad. It COULD be your problem.
In my case, the oil light would flicker, and upon inspection, the oil pressure sensor was leaking oil through its connector.
This is actually fairly common for Civics with D motors. The sensor is cheap from an auto parts store.
I will warn you - the end of the sensor can snap off in the block if it's badly corroded or if you just aren't careful with removal/install.
Old 03-03-2014, 04:10 PM
Stancetard Hate Monger
eghatch9295's Avatar
screen on the pickup in the oil pan could also be partially clogged. you'd need to pull the pan off to check. first thing- check pressure.
Old 03-03-2014, 10:18 PM
MisereNoire's Avatar
1. Check oil level
2. check sensor condition, replace if necessary (like stated above, it's cheap)
3. check for dents/concave surface on oil pan, it can cause clearance problems with the pickup
3.5 PRESSURE TEST (can go anywhere above here)
4. check for clogged pickup (this is also the time to assess any seals under there just in case/ and check for any particles in your oil, seeing as you'll need to drain to check this step)
5. if none of the above is wrong...you get to tear into your engine...oil pump, bearings....at this point i suggest reading your FSM in-depth.
if I left anything out, i'm sure it'll be corrected by anyone else on here with a grain of sense and extensive knowledge.(and thanks for any additions/corrections)
curtie94
01-31-2012 06:16 PM
shrirag
04-11-2007 09:55 AM
sublimenerd
16
09-25-2006 02:33 AM
turboh22chick
01-13-2005 09:09 PM
PatrickGSR94
12-19-2004 07:45 PM
Quick Reply: Oil light flashing
