Overheating issue please help :)
Old 01-06-2012, 05:45 PM
cadwiese's Avatar
Default Overheating issue please help :)
So i was driving my civic home today and i realized at a stop light that my car was getting above the half way point on the temp gauge. Thinking that it would maybe go down when i started driving i proceeded home....it got hotter I pulled over at a gas station and thought maybe the fan didnt turn on so i poped the hood and saw that it was on. I touched that radiator cap and it wasnt hot so i didnt the dumb thing and opened it and got fluid everywhere Im guessing that my thermostat has went bad but what do you think?
ty in advance
Old 01-06-2012, 05:48 PM
EK9
Dc4LsTeG's Avatar
Default Re: Overheating issue please help :)
Did you feel your bottom hose?does your top hose look like its expanded
Old 01-06-2012, 05:49 PM
cadwiese's Avatar
both hoses look good but the bottom seemed hotter then the top
Old 01-06-2012, 05:52 PM
The Grumpiest
grumblemarc's Avatar
I think at the very least you should try and replace the thermostat.
Old 01-06-2012, 05:54 PM
cadwiese's Avatar
ya and im going to replace the cap also....
Old 01-06-2012, 05:56 PM
The Grumpiest
Curious. When was the last time the timing belt/water pump was replaced?
cadwiese's Avatar
12k ago when i rebuilt the engine
Old 01-06-2012, 06:51 PM
Seagull Management
94EG8's Avatar
You're lucky, you can get some pretty nasty burns that way. If you have a blown headgasket especially that cap can be under a hell of a lot of pressure.
Try a new thermostat and cap and go from there (oem not aftermarket junk, I've had some many issues with aftermarket thermostats it's not even funny)
I would also do a compression test on it. Maybe do that first actually.
TheWizard14
09-07-2015 01:34 PM
motegicivic
07-14-2012 04:39 PM
Utilitarian
09-14-2007 11:20 AM
silvsrt4
10-01-2005 04:25 PM
Typiko512
10-01-2002 07:31 AM
Quick Reply: Overheating issue please help :)
